Old 26th July 2017, 09:46 AM
It's very common for the shaft sleeves of the fan to get clogged up with carbon from the brushes.
You can often get away with a clean of the centre housing.
Tapping it may give you temporary relief, or try manually ramping the fan speed up to full and see if it will go doing that.
Easy to get at fan, it's the first thing you come to under the fresh air intake grille and shut off flaps.
Good write up on Audipages for fan replacement, take the procedure as far as required...
Thanks for that, especially the Audipages link, missed it yesterday.
Old 26th July 2017, 10:11 AM
I've just done one. Not easy at all, although I had the engine out which helped considerably!
The Audipages write-up doesn't make it look too bad, though there is no mention of rusted screws there.....
And they do seem to have a special tool, similar to what you describe, to get at the awkwardly-located ones.
I guess with the engine out you can get right up to it quite easily.
I'd be interested to hear how Ainars got on when he did it.
Old 26th July 2017, 01:04 PM
As an aside, I also notice that the black foam around the outside (that seals against the bonnet) is falling apart, I even got bits of it blown into car during testing.
Is this a "thing" that's worth buying (if available) or would any decent foam of suitable thickness do?
Old 26th July 2017, 02:05 PM
27litres's Avatar
27litres 27litres is offline
I replaced my foam shortly after buying the car.
Readily available from Audi.
Part number 4D0820513A.
I'm personally tempted to take a look at generic auto rubber supplies to see if there's a suitable rubber seal to use instead. Probably pointless, as I reckon the seal weakness is at the sides anyway...
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 31st July 2017, 01:15 PM
The fan has behaved very oddly over the weekend, sometimes working and sometimes not. And turning the speed up to max makes no difference at all, it just seems to decide to work, sometimes mid-journey
Just been out to the car, it's pretty thick cloud at present, and the fan is just ticking over slowly driven by the solar panel.
IIRC that's driven directly with a relay that switches over to HVAC control/power when the ignition is on.
My thinking is that if it was the fan bearings or motor that are at fault then a low voltage input from the solar panel wouldn't make it work at all (and a high fan speed setting might prod it into life), so my suspicion still currently is focussed on the connector/wiring and some sort of poor/intermittent contact.
Currently awaiting some "bits" from A8parts that should assist with diagnosis.
Old 31st July 2017, 01:51 PM
Motor speed controller?
Old 31st July 2017, 02:32 PM
It fails equally on solar or HVAC control (including REST) so has to be something pretty fundamental/simple.
To clarify:
What I meant was that if it's not turning over changing the fan speed (applying higher voltage presumably) doesn't kick it into life.
If it IS working the controls all act as normal.
Old 1st August 2017, 08:07 AM
I did mine too my motor would pick up speed cornering, rusty screws 4 of them snapped off i think. Removed the awkward ones with a bit in small ratchet. Replacement motor from A8Parts and asked for one from car without solar.
Linky to previous post
Old 1st August 2017, 09:10 AM
Ah, did you mean the thing, mentioned here as hedgehog-like? http://forum.a8parts.co.uk/showpost....35&postcount=5
I didn't even know it existed though I had seen the cooling fins. Is it directly in the circuit to the motor (I would assume not) or "just" another input to the HVAC system?
PS. Just been out to check today's status and I can hear the fan ticking over nicely driven by the solar panel.
Old 2nd August 2017, 10:14 AM
Readily available from Audi. Part number 4D0820513A.
I've ordered some generic weatherproof foam strip, 19mm wide and 10mm thick.
Three metres for a fiver, delivered. Should allow a few replacements if needed.
