Old 13th November 2018, 05:49 PM
Originally Posted by RS6 View Post
took me ages to get the wood back on and lined up again
In the short term you don't need all the fixings, maybe just one screw is enough.
But you do need to make sure that the heavy insulating/waterproof layers that overlap it at the top are in the right place.
Old 13th November 2018, 06:31 PM
It is a fiddly job that's for sure, made all the more difficult by having to contort yourself upside-down in the footwell! Always takes me ages to get the damn thing back on too!
The wood, compressed cardboard, or whatever it is, is awful too. I replaced mine a couple of years ago with 'tile-backer' board lined with foam rubber:
http://forum.a8parts.co.uk/showthread.php?t=11673
Old 17th November 2018, 06:38 PM
RS6's Avatar
RS6 RS6 is offline
Mark good work with that custom fix
I heard back from the garage friday!
Well it wasn't the hazard switch unfortunately...
The fault has been traced to a relay on the part of the electric circuit / board which has corroded terminals. It has corroded because where this electric circuit sits (passenger side under the carpet up by the back of the glove box) is full of water.
All blockages up around the scuttle panel and drain tubes have now been cleaned out and there is no ingress into the car on this side
some of the corroded wires have now been repaired and it looks like just the one relay will be required arriving monday
Cars also in for MOT, service, coilovers and wheel spacers
Abarth 500 Esseesse - Sold
RS6 Avant Black - Stolen
Mercedes Benz CLS 500 - Sold
Corsa VXR Nurburgring - Sold
RS6 Avant Grey - Sold
Seat Leon Cupra R - Sold
Old 17th November 2018, 06:42 PM
Exactly per Sergey's thread then! Have you done Botang's hole?
Old 17th November 2018, 07:17 PM
RS6's Avatar
RS6 RS6 is offline
I have sent the instructions over hopefully they can block it off
Old 19th November 2018, 08:49 PM
RS6's Avatar
RS6 RS6 is offline
Big thanks to Sergey's thread! garage followed the guide and blocked off the hole
Old 19th November 2018, 09:53 PM
