Old 21st February 2019, 11:44 AM
Well my wheels haven't fallen off yet I've run a set of these on my daily driver for about 10 years, and I also have a set of adapters in the same design to run the Q7 20s on my S8.
The wheel bolt threads in to a steel insert which is pressed in to the alloy spacer from behind. The insert is as thick as the car's hub so no less strong
Old 21st February 2019, 11:51 AM
27litres's Avatar
27litres 27litres is offline
14mm x 70mm...
No problem!
The load on wheel bolts is in tension.
Provided they are torqued correctly there is no shear load, and almost no bending moment. All shear load is born by friction on the mounting surfaces, even during acceleration and braking.
A 14mm x 50mm bolt will not have any significant increase in twist (along the shaft) compared with a 14mm x 70mm bolt either, and the tensile load they can withstand is equal.
If you're using hub centric spacers, they will centre the wheel on the hub properly making sure the bolts align.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 21st February 2019, 12:48 PM
roberto's Avatar
roberto roberto is offline
trouble is i cant find any 70mm ones anywer
Old 21st February 2019, 01:01 PM
Are the Merc wheels taper or radius seat? There are four listings for M14x1.5 x 70 with taper seats on ebay.
Old 21st February 2019, 03:09 PM
I've used this guy before for wheel nuts and bolts - very knowledgable
http://www.speedshack.co.uk/Wheelnuts.htm
Old 21st February 2019, 03:36 PM
roberto's Avatar
merc are radius bolts but different to Audi
speedshack longest 64mm NO stock special order
no problem if not using spacers straight on with the merc standard bolts
Old 22nd February 2019, 04:03 AM
roberto's Avatar
Default this is how it looks at the moment
perfect setup right now and the odd 5mm makes a big difference in looks
Old 12th March 2019, 07:17 AM
roberto's Avatar
ive decided to sell these lovely Mercedes wheel that are now fitted with brand new tyres so i will list them on here first..
Old 12th March 2019, 10:43 AM
You can only have them if you slam it and wear the hoodie and have the chimpanzee swagger to match
