![]() Quote:
All you need to have to code it in is VCDS no?
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU Last edited by classexa; 28th February 2020 at 02:30 PM. |
I'm sure I've got a couple of modules as Spares so if you can post your modules exact codes then I'll have a look
![]() Quote:
Pump - 4E0614517E/0265225197(Bosch number)
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU |
![]() Quote:
programming should have (in theory) been a straight forward task, but the garage could not do it. In the end I called a chap over who does all VAG coding and he sorted it. It's worth pulling the code first before you swap/replace. My car would often throw up ABS module codes - loads of other related bits would be affected. |
![]() Quote:
I think I got the coding part figured out so that shouldn't be a problem
Hello again. Got the module back from repair and it works
![]() However, a new problem showed up. After I calibrated the air suspension(successfully), a new fault code showed up in the ABS module: 01435 - Brake Pressure Sensor 1 (G201) 012 - Electrical Fault in Circuit Wonder if it was because I did several calibration attempts and the car was going up and down, maybe the wiring couldn't take it. I checked in VCDS and it has a constant pressure of 291 bars, regardless of if I press the brake pedal or not. According to VCDS that means "short to plus". I tried to remove the connector from the sensor and it still showed 291 bars. Does that mean it's the wiring or could it be the sensor? Also, the ABS light(yellow), ESP light and parking brake warning light now appears. The only code in the parking brake module refers to the ABS module and the only code in the ABS module is the pressure sensor code. So could all of these warning lights be because of the pressure sensor code?
A8 D3 2003 4.2 Quattro Engine: BFM / Gearbox: GNU Last edited by classexa; 14th March 2020 at 08:58 PM. |
Isn't the sensor internal in ABS pump? So not sure what you unplugged.
After searching online it looks like it is separate sensor on that can be changed on ABS pump on D3. You can probably measure resistance at the pins. I don't know what the values should be but if it is short or open you can be pretty sure it's faulty.
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 15th March 2020 at 08:34 AM. |
![]() Quote:
Yeah, replacing the pressure sensor didn't solve the problem. If that wasn't enough, all the brake fluid went seeya from the ABS unit so I had to bleed it all. YAY! It's all pointing to the ABS module. One problem gone, a new one shows up. Guess it's time to try find a new/used module
#30
Phaeton ones look the same but are much cheaper, I wonder what the difference is ? Their part number starts 3D0.
