Old 24th April 2012, 09:28 PM
RanjS8 RanjS8 is offline
Default Clutch Master
The clutch master cylinder will either have to be mounted at an angle or possibly be mounted in the engine compartment with a rod type or spring type mechanism mounted on the clutch pedal to press on it.
I wouldnt worry about the footrest issue at present...just a working pedal cluster is the priority. I truly believe this is possible now...
