D2 - Sat Nav, ICE, Audio & TV All in car entertainment discussions |
Thread Tools
Display Modes
I think your right, I have driven 144 miles this morning and its now spot on. At least I have a map to look at, unlike the basic text nav that went before. However it is very basic when compared to the RNS-510 I had in my previous car, but I am glad to be able to see on a map my location again.
Just need to hook up the power to the TMC and the patch into the cluster can signal then the job is finished.
And I think we are there.
All connected, complete with Navigation instructions on the DIS. However, I have the following to resolve. 1) With the radio connected through the TMC module there is no reception, I have the radio aerial directly into the RNS-D and it works fine. Not sure why this does not work, might not even be worth sorting as the later DX UK nav discs no longer have TMC data. Lastly 2) Although the navigation data is displaying on the DIS, the radio station info is not at the top like it was on the Symphony. I have tried turning it off and on again in the DIS menu but this is still missing. I have a feeling this maybe a coding issue, although I don't know where to start. Pasted below are the results of a current VCDS scan. Saturday,15,September,2012,15:05:20:10074 VCDS Version: Release 10.6.4 (x64) Data version: 20110418 -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4D - Audi A8 D2 Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77 02 VIN: WAUZZZ4DZ1NXXXXXX ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No: 4D0 907 558 N Component: 3.7l V8/5V G 0001 Coding: 11753 Shop #: WSC 02313 VCID: 387B2CD332C3 WAUZZZ4DZ1NXXXXXX AUZ7Z0Y1573817 No fault code found. Readiness: 0110 1101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D46 Coding: 08397 Shop #: WSC 23132 VCID: 316D11F7D1B9 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: VCID: 55A585678591 Note: Excessive Comm Errors ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4D0-959-655-AI8.lbl Part No: 4D0 959 655 T Component: Airbag Front+Kopf 4000 Coding: 01417 Shop #: WSC 02335 VCID: 43814B3F7B05 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: Part No: 4D0 919 035 AJ Component: D2-KOMBIINSTR. VDO D29 Coding: 00483 Shop #: WSC 02313 VCID: 6ED7CA8B0007 No Faults Found or DTCs not supported by controller or a communication error occurred ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8L0 862 257 P Component: CV-Pump, Alarm, RC D17 Coding: 13130 Shop #: WSC 00000 VCID: 428F4E3B641F No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: Redir Fail! Part No: 4D0 035 192 M Component: RNS 4.2 H06 BNO 0140 VCID: 295DF997F969 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: 4B0-907-357-DYN.lbl Part No: 4B0 907 357 C Component: dynamische LWR D05 Coding: 00001 Shop #: WSC 00000 VCID: 285BFC93E263 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: Redir Fail! Part No: 4D0 035 192 M Component: Radio BNO 0001 Coding: 00017 Shop #: WSC 00976 VCID: 295DF997F969 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4D0-919-283.lbl Part No: 4D0 919 283 Component: Parkingsystem A8 RDW D07 Coding: 01108 Shop #: WSC 00000 VCID: E8DB3C93A2E3 No fault code found. ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01V-927-156.lbl Part No: 4D0 927 156 DD Component: AG5 01V 3.7l5V RdW 3838 Coding: 00001 Shop #: WSC 02313 VCID: 6ED7CA8B0007 No fault code found. End ---------------------------------------------------------------------
Sorted the radio display problem on the DIS.
VCDS - Controller 17, instruments, Adaption 10. Channel 62, previously set to 4, now set to 5 as per a post I found elsewhere on the internet. Bingo, Radio data now displaying in DIS, same with CD number and track info. So all is now well apart from the TMC aerial leads not working. Refitted the instrument cluster, and found it really difficult to push back in. I hope all is well back there, as I have added quiet a lot behind the cluster.
As I recall, TMC only ever worked on mine if tuned into Classic Radio, or whatever it's called, have you tried that?
it picks up no stations at all, only static with the TMC module in the loop. Then when you scan the radio with VCDS there is an antenna fault error.
I have left the module bypassed for radio now, everything else works perfectly.
If the TMC was from my old car, it may possibly be faulty. When I bought the car the radio reception was non-existent. The car had a new aerial fitted in place of the phone aerial. I knew Ranj was going to fit the RNS-E, so never went too much into the details of what happened when I got the car, therefore he was unaware that there may be a problem with it.
the tmc module is from a different car.
I found with Reffro's car that the aerial was totally aftermarket and the wiring from the aerial had a connector which was not quite compatible with connector on the back of the rns d....someone had taped the two connectors together hence not a good connection.... I dont think tmc module would cause issue with radio reception to be honest, but it is on my to do list.
01 Audi a8 fl sport - Grey, Bose, Glass Sunroof, S8 grill/mirror covers/wheels, Aftermarket Exhaust, very quick and lots of fun!!!!!....well I gave it one final push on the pedal to hear that v8 growl and then it was off to a new home..... 99 Audi a8 fl - Silver, Black alcantara seat/ S8 grill/side mirror, MFSW, Solar Sunroof, 17" Monoblocks (for that extra cushion of air), Rnsc, Bose.....great motorway cruiser....now gone to a new home 02 Final Edition S8 - Avus Silver, Extended Leather Pack III, Front & Rear Heated Seats, Servo, Blinds, Rear Seat Entairtainment with Playstation, Bose, Bi Xenons.....now gone to a new home 97 PF A8 4.2 quattro sport - Cashmere Grey, Servo, RNS E, Blinds, Bose, 20 Final Edition Alloys, LPG....sold sadly and will be missed 03 S4 V8 Saloon - Misano red, Manual, Milltek, Bose, Xenons, RNS E - Sold as of Feb 2012 |
I dont mind the fact the TMC does not work for Radio, it would have just been good.
Looking at the guide to install the RNS-E, maybe in the future. Having completed this I now feel that an E install is far simpler in comparison.
The issue with an rns e install is the getting the unit at the right price as you need one from an a6 so you can trim the sides down, which are normally quite pricey around the 5-600 mark.....unless you can get hold of the fascia off a broken rns e....
I would keep an eye out for a broken rns e from an a6....and then get the cheaper rns e's from an a3 and switch the fascias over. Managed that and the rest will be a doddle....the annoying element is that you lose the dis instruction on the instrument cluster...otherwise plain sailing once you have done a rns d instal.
#30
![]() Quote:
