Old 21st December 2012, 02:00 PM
71camaro 71camaro is offline
I don't know... Here (http://www.raintracker.com/rt_more_info.php) it looks awful IMHO.
How about transplanting this system from another model of Audi? D2's mirror isn't attached to windshield, so perhaps it helps.
I think you must be confused as to the size. Sensor is about the third the size of a business card.
Old 21st December 2012, 02:16 PM
If it's 1/3 of business card, can it be placed within the darker band of windscreen right behind rear view mirror?
Old 21st December 2012, 02:50 PM
Good question. I note from their drawings and picture that its positioned below the tinted/shaded area of the screen. That may indicate that the IR sensor may not work so well in the tinted area due to absorption. My screen has a very dark band about 30 - 40mm in width but below that its clear and if mounted in that area its around the same height as the mirror and, would be perfectly acceptable. Its a question worth raising with the company.
Old 11th May 2013, 09:38 PM
I have this installed now. I'll provide pics and wiring info in the near term. I installed the sensor at the base of the windshield. It's out of the field of vision when driving, and looks OEM or near so. I positioned it such that the wiring connector looks about like your standard VW/Audi wiring cover. I've thought about blacking out the windshield around where it's mounted in a nod to OE goodness but haven't done so yet. I've had a number of people ride in the car since install and no questions as yet.
I have the on/off switch run into the console and to the trim where phone prep items are in the console cubby. I also have an OEM A4 AUX-In radio connector there.
I can't speak to whether the rain sensing portion works well yet, seemed to in tests with a hose, but haven't gotten any rain recently. I do know the auto-lamps work well. At dusk they start to operate without any effort. I have it so that I can override and use only park lamps as well with the lamp stalk and without disabling rain tracker.
Old 12th May 2013, 11:20 AM
Jeez, you could test them here, no problem! It's forgotten how to stop raining.
Old 12th May 2013, 05:56 PM
I can't speak to whether the rain sensing portion works well yet, seemed to in tests with a hose, but haven't gotten any rain recently. .
I had to read that twice! before I realised that there are places like that.
Look forward to seeing the write up.
