Old 18th April 2009, 03:20 PM
Default How to change a V8 (I hope) :)
This thread is about my engine swap. It is not meant as a 'How To' as as I am making it up as I go along. I have removed a couple but never put one back.
I will be using a mix of AudiPages information and erWin printouts plus the experience I've gained from removing them. Now I know what your thinking; and yes I'm only doing it because I have no choice and I've always had suicidal tendancies.
So prior to starting I ordered up some parts from Audi. I have to swap the inlet manifold as mine is modded for LPG. So I have orderd the inlet manifold gaskets, Throttle Body gasket, Sump Plug Gaskets for engine and tranny, O-ring seals for ATF oil cooler pipes, Allen bolts for Torque Converter to flywheel.
After the engine arrived I have order up an exhaust seal, bolts and nuts.
Anyway a few photos:
As the engine came minus the cling wrap.
Mounted on the engine stand.
A shot most of us hope never to see...........
The first thing I had to do was remove the wiring harness as mine is modded with hard wiring for the LPG. Some kits have a plug in additional harness that goes between the injectors and wiring harness mine is soldered into the original. This was not as difficult as it may seem as being German its fitted in a logical and ordered manner.
Once the harness has been removed.
The harness as it came off.......... Lots of cable ties (Lots)
Out with the Inlet manifold, just 4 bolts and 4 nuts, a tap or 2 with a soft face mallet and ..........
Something to polish?
Next up is the cleaning. AS I have the engine on the stand I'm also going to do some preventive work and replace most of the hoses that are hard to do when in the car.
Tags
4.2 v8, engine swap, s8 ahc
