Old 23rd February 2014, 09:52 PM
Can't remember exactly where.. but either in the CAN gateway, central module or climate module there's a setting for RHD/LHD car. Functionally, it makes no difference that I saw, but having the correct labels is nice
Old 1st March 2014, 08:59 PM
Nollywood's Avatar
Default Update!
After going through settings in the secret menu, I managed to effect some changes.
So I now have the DIS fully functional once more - Navigation and Radio details display in the dash as they should. I have the car booked into Audi on the 31st March, to remove Component Protection. Hopefully, things will be fully resolved.
CP after MMI update to 5570 is pretty common, causing audio on the right hand speakers to cease, and BOSE surround is disabled.
I'll post some logs, perhaps some members can throw some light on things. Thanks in advance for your responses.
Old 1st March 2014, 09:03 PM
Nollywood's Avatar
Default First VCDS Log, Pre-MMI Update To 5570.
Sunday,23,February,2014,13:54:19:13314
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 4E0
Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 28 34 36 37 38 42
46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4EX4N019359 Mileage: 246250km/153012miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: Malfunction 0010
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
1E-Media Player 2 -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: Malfunction 0010
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: Malfunction 0010
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 0010
67-Voice Control -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Malfunction 0010
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 Q HW: 4E0 907 560
Component: 4.2L V8/5V G 0030
Revision: 00000000 Serial number: AUX3Z0D0332330
Coding: 0011773
Shop #: WSC 00759 210 91871
2 Faults Found:
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - Implausible Signal - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2L5V RdW 0110
Revision: 00000001 Serial number: 0029737
Coding: 0000001
Shop #: WSC 02312 823 51201
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 M
Component: ESP 5.7 allrad H44 0500
Coding: 0008597
Shop #: WSC 00759 000 00000
2 Faults Found:
00532 - Supply Voltage B+
000 - - - Intermittent
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 C
Component: FBS AUDID3 H03 0140
Revision: 01403903 Serial number: AUX3Z0D0332330
Coding: 0411648
Shop #: WSC 02311 785 00200
Part No: XXXXXXXXXXX
Component: ELV XXXX
10 Faults Found:
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
001 - Upper Limit Exceeded
Freeze Frame:
Fault Status: 01100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 107
Mileage: 196416 km
Time Indication: 0
Date: 2011.09.28
Time: 17:19:22
00183 - Interior Access/Start Authorization Antenna 1 (R138)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 4
Fault Frequency: 0
Reset counter: 107
Mileage: 196416 km
Time Indication: 0
Date: 2011.09.28
Time: 17:19:22
00956 - Key 2
Freeze Frame:
Fault Status: 01100010
Fault Priority: 4
Fault Frequency: 1
Reset counter: 110
Mileage: 233488 km
Time Indication: 0
Date: 2013.01.18
Time: 12:20:42
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 240144 km
Time Indication: 0
Date: 2013.05.25
Time: 03:51:22
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 43
Mileage: 241600 km
Time Indication: 0
Date: 2013.07.23
Time: 18:32:52
00193 - Right Rear Door Handle Touch Sensor (G418)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 95
Mileage: 0 km
Time Indication: 0
00190 - Driver's Door Handle Touch Sensor (G415)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 95
Mileage: 245280 km
Time Indication: 0
Date: 2013.12.24
Time: 07:48:56
00668 - Supply Voltage Terminal 30
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 245888 km
Time Indication: 0
Date: 2003.10.08
Time: 00:12:56
01331 - Door Control Module; Driver Side (J386)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 4
Fault Frequency: 0
Reset counter: 84
Mileage: 245920 km
Time Indication: 0
Date: 2014.02.13
Time: 17:55:40
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 13:44:20
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H07 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063840
Shop #: WSC 02313 785 00200
1 Fault Found:
Freeze Frame:
Fault Status: 00000010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 0 km
Time Indication: 0
Date: 2004.01.01
Time: 00:00:00
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 730 Q HW: 4E0 035 729 A
Component: Interfacebox H43 2120
Revision: 00000000 Serial number: 300AE047529272
Coding: 0000000
Shop #: WSC 00000 000 00000
Part No: 4E0 910 609 A
Component: Bedienteil MMI H42 0020
3 Faults Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246170 km
Time Indication: 0
Date: 2014.02.23
Time: 12:24:29
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
00446 - Function Limitation due to Under-Voltage
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2003.10.08
Time: 00:13:00
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 016 0240
Revision: 00000022 Serial number: 00000000035351
Coding: 1069137
4 Faults Found:
00066 - Right Rear Footwell Heater (Z43)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 46
Mileage: 243348 km
Time Indication: 0
Date: 2013.10.27
Time: 09:12:20
Freeze Frame:
Voltage: 12.60 V
00819 - High Pressure Sensor (G65)
010 - Open or Short to Plus
Freeze Frame:
Fault Status: 01101010
Fault Priority: 3
Fault Frequency: 14
Reset counter: 113
Mileage: 237365 km
Time Indication: 0
Date: 2013.01.22
Time: 20:36:40
00065 - Left Rear Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 14
Reset counter: 86
Mileage: 245418 km
Time Indication: 0
Date: 2013.12.31
Time: 12:58:53
Freeze Frame:
Voltage: 13.20 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 79
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 08:11:28
Freeze Frame:
Voltage: 7.80 V
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 G HW: 4E2 955 113 B
Component: ILM Fahrer H12 0170
Coding: 0123001
Shop #: WSC 02314 785 00200
Part No: 4E2 910 113 B
Component: Wischer WWS D3 H40 0400
Coding: 00000036
Shop #: WSC 02314
Part No: 4E0 910 557
Component: REGENLICHTSENSORH10 0030
Coding: 00139548
Shop #: WSC 02314
3 Faults Found:
01024 - Rain Sensor (G213)
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2003.10.08
Time: 18:16:57
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2003.10.08
Time: 18:16:57
00908 - Control Module for Wiper Motor
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 86
Mileage: 0 km
Time Indication: 0
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655 G
Component: Airbag 8.4E+ H10 0940
Coding: 0431707
1 Fault Found:
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0112141
Component: Lenkradmodul H02 0050
2 Faults Found:
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 86
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 86
Mileage: 245898 km
Time Indication: 0
Date: 2003.10.08
Time: 00:13:19
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 C
Component: KOMBIINSTR. VDO H44 0090
Revision: D15 Serial number: AUDID3D0000829
Coding: 0000403
Shop #: WSC 01221 210 182300
2 Faults Found:
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 2
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.05
Time: 10:47:07
02095 - Component Protection Active
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2003.10.08
Time: 00:00:29
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 A
Component: Gateway H07 0070
Revision: 07 Serial number: 1400303C022DA2
Coding: FCFE7FDC2B7504
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.05
Time: 14:36:59
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111
Component: CD-Changer H43 0470
Revision: 00000501 Serial number: AUZ5ZBD1031965
4 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 09:57:29
02446 - Disk Drive Mechanical Malfunction
Freeze Frame:
Fault Priority: 7
Fault Frequency: 6
Reset counter: 157
Mileage: 242787 km
Time Indication: 0
Date: 2013.10.11
Time: 17:35:40
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 63
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 13:35:06
Freeze Frame:
Text: 00000510
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 08:12:07
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0411648
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
10 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 107
Mileage: 196416 km
Time Indication: 0
Date: 2011.09.28
Time: 17:19:22
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 107
Mileage: 196416 km
Time Indication: 0
Date: 2011.09.28
Time: 17:19:22
00956 - Key 2
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 110
Mileage: 233488 km
Time Indication: 0
Date: 2013.01.18
Time: 12:20:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 202
Mileage: 240144 km
Time Indication: 0
Date: 2013.05.25
Time: 03:51:22
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 43
Mileage: 241600 km
Time Indication: 0
Date: 2013.07.23
Time: 18:32:52
Freeze Frame:
Fault Status: 01100111
Fault Priority: 3
Fault Frequency: 14
Reset counter: 55
Mileage: 0 km
Time Indication: 0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 14
Reset counter: 55
Mileage: 245280 km
Time Indication: 0
Date: 2013.12.24
Time: 07:48:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 81
Mileage: 245888 km
Time Indication: 0
Date: 2003.10.08
Time: 00:12:56
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 84
Mileage: 245920 km
Time Indication: 0
Date: 2014.02.13
Time: 17:55:40
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 0
Reset counter: 95
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 13:44:20
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158
Component: KLIMA-STG. FOND 015 0210
Revision: 00000014 Serial number: 00000000014873
Coding: 0000000
1 Fault Found:
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 F HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 6260
Coding: 0015510
5 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 60
Reset counter: 94
Mileage: 241313 km
Time Indication: 0
Date: 2013.07.02
Time: 17:11:34
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 81
Mileage: 0 km
Time Indication: 0
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.05
Time: 16:58:43
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.05
Time: 16:58:50
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 86
Mileage: 245998 km
Time Indication: 0
Date: 2003.10.08
Time: 00:01:25
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H07 0060
Coding: 4063850
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 80
Mileage: 245896 km
Time Indication: 0
Date: 2014.02.06
Time: 08:15:01
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 D HW: 4E0 919 887 C
Component: MNS ECE H43 0550
Revision: 00000000 Serial number: 305AF047553820
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 80
Time Indication: 0
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 08:11:45
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0090
Serial number: 00000402700074
Coding: 0035984
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 84
Mileage: 245928 km
Time Indication: 0
Date: 2014.02.13
Time: 17:55:00
Address 42: Door Elect, Driver Labels: None
Part No SW: 4E1 910 802 B HW: 4E2 959 802 B
Component: Türsteuer.FS BRMH01 0060
Coding: 0032622
5 Faults Found:
02110 - Window Regulator Switch
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 94
Mileage: 245744 km
Time Indication: 0
Date: 2014.01.21
Time: 07:35:14
02111 - Motor for Window Regulator
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 245888 km
Time Indication: 0
Date: 2014.02.07
Time: 10:17:26
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 245888 km
Time Indication: 0
Date: 2014.02.07
Time: 10:17:26
00461 - Control Module for Seat Memory; Passenger (J521)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 80
Mileage: 0 km
Time Indication: 0
01308 - Control Module for Roof Electronics (J528)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 80
Mileage: 0 km
Time Indication: 0
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040401220055
Coding: 0004857
Part No: 4E0 910 853
Component: Heckdeckel H06 0060
Part No: 4E0 907 719
Component: Neigungssensor H03 0020
6 Faults Found:
01134 - Alarm Horn (H12)
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
02107 - Trunk or Luggage Compartment Opening Motor (V254)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.05
Time: 16:59:06
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
01503 - Bulb for 3rd Brake Light (M25)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 81
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 08:09:26
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 94
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 09:58:22
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 84
Mileage: 245928 km
Time Indication: 0
Date: 2014.02.13
Time: 17:55:43
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 G HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0360
Revision: PROD_01 Serial number: 00000000201652
Coding: 0000027
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 5
Reset counter: 80
Mileage: 245898 km
Time Indication: 0
Date: 2014.02.06
Time: 08:15:06
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H08 0020
Revision: Serial number: 00000000032526
Coding: 0010101
Old 1st March 2014, 09:08 PM
Nollywood's Avatar
Default 2nd VCDS Log.
Sunday,23,February,2014,14:00:23:13314
Chassis Type: 4E0
Coding: 0011773
Readiness: 0110 1101
Coding: 0000001
Coding: 0008597
Coding: 0411648
Component: ELV XXXX
Coding: 4063840
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 13:55:56
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Coding: 1069137
Part No SW: 4E0 910 279 G HW: 4E0 907 279 G
Coding: 0123001
Coding: 00000036
Shop #: WSC 02314
Coding: 00139548
Shop #: WSC 02314
Coding: 0431707
Coding: 0112141
Coding: 0000403
Coding: 0411648
Component: ELV XXXX
Coding: 0000000
Coding: 0015510
Coding: 4063850
Coding: 0035984
Coding: 0032622
Coding: 0004857
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Coding: 0000027
Coding: 0010101
Address 52: Door Elect, Pass. Labels: None
Part No SW: 4E1 910 802 B HW: 4E2 959 801 B
Component: Türsteuer.BF BRMH01 0060
Coding: 0032622
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000531
Address 55: Xenon Range Labels: None
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0040
Coding: 0000002
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 L HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0560
Revision: 00000000 Serial number: 304BR047558890
Coding: 0000001
Address 57: TV Tuner Labels: 4E0-910-146.lbl
Part No SW: 4E0 910 146 E HW: 4E0 919 146
Component: TV analog TUNER H12 0270
Revision: 00000004 Serial number: 00000000006057
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 B HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0240
Revision: 00000000 Serial number: 00000000262164
Shop #: WSC 00976 210 16715
Part No: 000 915 105 AK
Component: von VA0 1401160348
Coding: 303030393135313035414B56413031343031313630333438
Shop #: WSC 00000 128 00289
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRMH01 0060
Coding: 0032622
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 K HW: 4E0 035 753
Component: SDS 3502 UK H43 0600
Revision: 00000000 Serial number: 00000401120163
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRMH01 0060
Coding: 0032622
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 A HW: 4E0 919 283 B
Component: Parkhilfe 8-Kan H11 0010
Revision: --.--.-- Serial number: 08730402100078
Coding: 0001008
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 F HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0770
Revision: 00000001 Serial number: 00000000000000
Coding: 0000004
End ---------------------------------------------------------------------
Old 1st March 2014, 09:10 PM
Nollywood's Avatar
Default 3rd VCDS Log, Post MMI Update.
Sunday,23,February,2014,17:44:20:13314
Chassis Type: 4E0
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
28-HVAC, Rear -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
47-Sound System -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Sporadic communication error 1000
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: Sporadic communication error 1000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Coding: 0011773
Readiness: 0010 1001
Coding: 0000001
Coding: 0008597
Coding: 0411648
Component: ELV XXXX
7 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 95
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 16:35:10
Coding: 4063840
4 Faults Found:
01881 - Lumbar Support Height Adjustment Button (E335); Down
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 246248 km
Time Indication: 0
Date: 2014.02.23
Time: 16:28:29
01880 - Lumbar Support Height Adjustment Button (E335); Up
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 246248 km
Time Indication: 0
Date: 2014.02.23
Time: 16:28:29
01883 - Lumbar Support Fore / Aft Adjustment Button (E336); Backward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 246248 km
Time Indication: 0
Date: 2014.02.23
Time: 16:28:30
01882 - Lumbar Support Fore / Aft Adjustment Button (E336); Forward
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 95
Mileage: 246248 km
Time Indication: 0
Date: 2014.02.23
Time: 16:28:30
Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A
Component: Interfacebox H43 5570
Coding: 0000002
Shop #: WSC 00000 785 00200
3 Faults Found:
01325 - Control Module for Tire Pressure Monitoring (J502)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:03:07
02849 - Control Module for Lane Change Assistance (J769)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:08:32
02873 - Control Module for Back-Up Camera (J772)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:08:32
Coding: 1069137
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 13:56:08
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 13:56:09
Freeze Frame:
Voltage: 13.80 V
Coding: 0123001
Coding: 00000036
Shop #: WSC 02314
Coding: 00139548
Shop #: WSC 02314
Coding: 0431707
Coding: 0112141
Coding: 0000403
3 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:14:26
01301 - Control Module for Voice Recognition (J507)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:17:07
00463 - Control Module for Digital Sound Package (J525)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:25:28
1 Fault Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 17:12:13
Freeze Frame:
Text: 00000000
Coding: 0411648
Component: ELV XXXX
7 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 14:22:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 16:35:10
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 17:42:20
Coding: 0000000
Coding: 0015510
Coding: 4063850
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H43 1060
1 Fault Found:
02927 - DVD Read Error
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 17:41:05
Freeze Frame:
Hex Value: 0x530A
Hex Value: 0x32ED
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0035984
Coding: 0032622
Coding: 0004857
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Part No SW: 4E0 910 223 P HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0460
Coding: 0000027
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:37:08
02084 - Component Protection
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:37:08
Coding: 0010101
Coding: 0032622
Revision: AV1C1010
Coding: 0000531
Coding: 0000002
Part No SW: 4E0 910 541 T HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0630
Coding: 0000001
Part No SW: 4E0 910 146 G HW: 4E0 919 146
Component: TV analog TUNER H12 0300
Coding: 0001003
Coding: 0032622
Part No SW: 4E0 910 754 S HW: 4E0 035 753
Component: SDS 3502 UK H43 0630
Coding: 0032622
Coding: 0001008
Coding: 0000004
Old 1st March 2014, 09:13 PM
Nollywood's Avatar
Default 4th VCDS Log, Post MMI Update.
Sunday,23,February,2014,18:13:30:13314
Chassis Type: 4E0
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
56-Radio -- Status: OK 0000
67-Voice Control -- Status: OK 0000
Coding: 0011773
Coding: 0000001
Coding: 0008597
Coding: 0411648
Component: ELV XXXX
5 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Coding: 4063840
Coding: 0000002
Coding: 1069137
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 17:57:06
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 17:57:08
Freeze Frame:
Voltage: 13.40 V
Coding: 0123001
Coding: 00000036
Shop #: WSC 02314
Coding: 00139548
Shop #: WSC 02314
Coding: 0431707
Coding: 0112141
Coding: 0000403
Coding: 0411648
Component: ELV XXXX
7 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
011 - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:54
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:10:56
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 55
Mileage: 246240 km
Time Indication: 0
Date: 2014.02.23
Time: 18:11:52
Coding: 0000000
Coding: 0015510
Coding: 4063850
1 Fault Found:
Freeze Frame:
Fault Status: 00100000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 95
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 17:58:13
Freeze Frame:
Hex Value: 0x530A
Hex Value: 0x36B5
Hex Value: 0x0401
Hex Value: 0x0000
Coding: 0035984
Coding: 0032622
Coding: 0004857
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Freeze Frame:
Fault Priority: 3
Reset counter: 245
Mileage: 146499 km
Time Indication: 0
Date: 2009.12.08
Time: 15:44:23
Coding: 0000027
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:37:08
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 55
Mileage: 246250 km
Time Indication: 0
Date: 2014.02.23
Time: 15:37:08
Coding: 0010101
Coding: 0032622
Revision: AV1C1010
Coding: 0000531
Coding: 0000002
Coding: 0000001
Coding: 0001003
Coding: 0032622
Coding: 0032622
Coding: 0001008
Coding: 0000004
Old 13th March 2014, 10:31 PM
Nollywood's Avatar
Anyone able to help with these logs?
Thanks in advance.
Old 14th March 2014, 06:22 AM
Might be worth copying them into the VCDS section as peeps not local to Heathrow might not be seeing them
Old 14th March 2014, 08:19 AM
Couple of issues:
1 - The keyless unit isn't happy. Could just be faulty antennas, but the unit is prone to water damage if you've ever had any in the car, so it may be dodgy. Worth getting the codes cleared and see if they return if the keyless usually works.
2 - Footwell heater - They break.. A little over £100 to replace the unit + labour
3 - High pressure sensor - Get it checked, your aircon probably won't work properly without it.
4 - Alarm horn - They do go.. not too hard to replace.
5 - CP - Either needs Dealer to reset, or may go when re-coded properly and codes cleared.
Old 22nd April 2014, 09:05 PM
Nollywood's Avatar
Update!
A long day today, Component Protection was finally removed from my '05 D3 4.2 Quattro, courtesy of Ipswich Audi.
Great service from those guys, and well worth the 220 mile round trip. It's good to have BOSE Surround back, and audio from both channels. They also threw in a set of new license plates, and fitted them too. My rear one was due laminating, and discolored. The rear fitted with the Ipswich Audi snap-lock frame.
Thanks guys for all your valuable help.
