Old 5th August 2014, 07:58 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Thumbs up Check Your Kickdown Switch
Found out my kick down switch was in the off position.
Not sure why but turned it back on it and BOOM kickdown, also no more fuel.
It appears the D2 facelift lads had their kick down switches turned off as well.
http://forum.a8parts.co.uk/showthread.php?t=50
Why would someone turn this off?
[center]
06 3.0TDI Quattro:
Options:
Old 5th August 2014, 06:48 PM
With the D2, you installed the kickdown switch by rotating it in the same direction as you do to disable the switch. I always guessed it was from factory that it was off as either someone was supposed to turn it back a notch during manufacture, or at least the PDI but was rarely done.....
It is a nice boost when you enable it after finding its been off sicne you got it...
Old 5th August 2014, 07:15 PM
audifin audifin is offline
Wow.. what a top tip! Mine was switched off, I had no idea
Old 6th August 2014, 07:37 AM
ScottD3's Avatar
For years most of these cars has had no kickdown.
Madness!!
[center]
06 3.0TDI Quattro:
Options:
Old 6th August 2014, 09:37 AM
Hi Ian - to clarify/check, on the D2, it's a turn and click to the right to enable kick down, but presumably a turn and click to the left to disable, or have I missed a trick here when it comes to the directionality of the switch?
Old 6th August 2014, 09:38 AM
No click, just turn it.
When it's in the right (right) position it will click when pressed.
Old 7th August 2014, 07:37 AM
Lyons Lyons is offline
D3 the same process I assume? How much does it turn each way?
Old 7th August 2014, 07:51 AM
ScottD3's Avatar
Yup same.
Not much, couple of MM
[center]
06 3.0TDI Quattro:
Options:
