Old 7th December 2015, 07:16 PM
Either way, if I was going to change the rear screen, I'd change it for a PF one as it is clear with no heating element lines. Its subtle, but looks much nicer imo
Thanks. Another great idea.
If you gonna change just door glass what are you planning to do with triangular glazing elements behind the rear doors? They should match door glass colour.
Old 8th December 2015, 09:56 AM
The rear quarters are heavily tinted, the remains of the ridiculous tint that the owner previous to Gordon apparently installed. I agree, my OCD wants them to match now you've pointed it out...
Doh. More work....
Old 9th December 2015, 03:06 PM
I think if you check the glass on all doors they are the match
For heated windscreen as all was changed over from the s8 I used as doner car I did replace 1 coil pack .
Old 9th December 2015, 04:21 PM
OOooh. Thanks for the heads up, you might have just saved me some effort
Still waiting on the number plate change btw. I'll forward the docs on as soon as I get em
Old 21st December 2015, 11:40 PM
Bushido Bushido is offline
Ian, you know where I am when you are ready for a professional paint detail.
No charge to you as you have helped me out enough along the way
May even be able to tempt big Ronnie to throw in some enthusiasm and roof work too!
"Ronnie! Ron! Woo hoo!!"
Actually, even if you would just like an extra pair of hands or eyes at any time. Would be fascinated to see one being stripped, fettled and rebuilt ...
Usually huffing, puffing and buffing in a dark corner somewhere...
Old 22nd December 2015, 08:16 AM
Glass has been checked - The glass you fitted is defo Heat and UV reflective, and so matches the heated screen. Thats saved me a job
Old 22nd December 2015, 08:19 AM
Problem I've got at the moment is that its getting done 30 mins here and there, I haven't got time for a big session on it at the moment - but - the offer a paint detail is of great interest - thank you - but you might regret it when you see how much detailing it needs.....
Old 22nd December 2015, 08:23 AM
Immediate job is to swap the engine ECU - The current ECU has almost certainly been fiddled with. It shows no errors. At all. Not even low oil, and many measuring blocks are absent. The remaining bit of wobble on the engine I suspect is a lambda off on one bank, but the ECU tells me nothing....
Well, swapped the Engine ECU, and made absolutely no different to anything. Well, ok, thats not strictly true. As I also had to swap the cluster, and now the faulty fuel gauge works perfectly, which has saved me fiddling around removing the gas tank to change fuel senders
Quite an interesting result that the original ECU was operating fine it seems. Also fitted 8 brand new coil packs and still suffering a slight wobble / hiccup. Guess Lambdas are the next item to check out....
Old 22nd December 2015, 08:45 AM
Norretal's Avatar
Norretal Norretal is offline
Oh he won't, he'd relish the challenge
Audi TT - 2015 - Ultra
Norretal's Avatar
I'm in
