Old 16th February 2018, 12:37 AM
H-M3 H-M3 is offline
Sorry to revive this thread. On this diagram which is the pipe I need to take off to flush the PS fluid? Also should I get the clips too? Or am I better off just using a suction tool to replace fluid?
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 17th February 2018, 08:44 AM
When I did it I removed both hoses from the cooler and plugged hose 10 to stop the oil draining from the tank, then fitted a bit of hose to the tube stub on the cooler and put that into a bucket. and refitted temporarily the forward hose (18) back onto the cooler. the reason for the extra hassle is to flush the cooler as well.
Then got the wife to start and quickly stop the engine, refill the reservoir and repeat until I got nice clean oil out.
To get access you need to remove the hose in front of the cooler to tank hose (10) so buy 2 clips (9)
Old 17th February 2018, 09:02 AM
Ok thanks, you never mentioned the wife bit on your original post! So now I have to find a wife too including 2 clips
Old 24th February 2018, 11:56 PM
Delboy any special tools needed to remove the clips on pipe?
Old 27th May 2018, 06:06 PM
homer simpson's Avatar
Well 3 days into ownership and my car lost power steering, fluid filing the undertray. So I took it apart today and found no.18 (cooler to rack) spewing out fluid.
Can anyone confirm this is definitely no. 18 in ETKA and the ones in the pics being removed? Thanks
Old 7th June 2018, 04:48 PM
Yes it definitely was this hose. New one ordered and fitted. Was a PITA getting it out as I was being very careful. Wasn't too bad putting new one on and best of all the seller paid the bill.
Old 9th January 2021, 07:30 PM
S81 S81 is offline
Thanks to del ( and homer for pointing me to his thread) i changed ps pipe today as part of winter maintenance and it's exactly as per details (and wasn't difficult when i knew how to do it ) , I haven't bleed the system yet as I'm doing other works and can't start car but will do the flush ect in due course,I did find this non oem joint behind the heat shield ,(it wasn't leaking)
ID:	25087   Click image for larger version
ID:	25088   Click image for larger version
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 9th January 2021, 08:19 PM
You're welcome. Looks like it had already failed in the past and someone f̶i̶x̶e̶d̶ bodged it
Old 9th April 2021, 01:17 AM
fjord fjord is offline
I am thrilled to join this club. My car took a #1 on the highway today. Sprayed the driver side wheel as well. The section behind the left fog light is all wet. I now have 2 A8s that cannot drive in my driveway
I will edit once I find the culprit.
Old 9th April 2021, 10:04 AM
steamship steamship is online now
Welcome along to the forum. As for 'editing' your post, just put up a new post of your findings.
Also take the time to introduce yourself... and your cars to everyone on the forum in the Introductions section. Photos are a bonus we all like. Also edit your details in the 'User CP' section (top left of page) to include things like location and create a signature for car details. This helps others when offering help to any questions.
