Old 10th January 2017, 10:27 PM
47p2's Avatar
47p2 47p2 is online now
Thats great thanks, worth giving it a try
Nite Blue 3.0L SE Quattro
Old 11th January 2017, 09:46 AM
woodpoleman woodpoleman is offline
At £18.00 certainly a cheaper test than an alternator, starter motor, comfort ecu, ignition switch, battery, coding and labour!!!
Since new - 2005 (05) Akoya Silver 3.0 TDI Quattro everything standard except wheels. 145,000 miles.
Bought at 9 months old - Ming Blue 2001 (51) 2.8 Quattro Sport with Sat Nav. 122,000 miles
Old 11th January 2017, 12:05 PM
Just to add - here's a couple of pictures, at the base of the large terminals of 370 it shows there's been some heat.
ID:	15382   Click image for larger version
Old 11th January 2017, 12:15 PM
Great result mate
Is your problem fully solved now ??
Old 11th January 2017, 12:54 PM
Can't say for sure yet only had the car back a couple of days. First short journey stopped and started three times no problem. Biggest change is that, once glow plug light has gone out, there is no lag between turning the key and starter motor cranking. Hopefully it's a fix, if not I'll post again before I top myself
Old 11th January 2017, 01:58 PM
Thanks for the update, mine has the occasional problem of what sounds like a lazy starter motor or bad earth when the engine is up to temperature. It doesn't happen every time but if I don't do something about it I'll be left stranded in the future.
Do you know the part numbers for J329 (370), J53 & J695 (381)?
This could also be crankshaft position sensor which happened on mine, always started fine from cold but didnt fire up at all when warm/hot sometimes.
Gradually got worse until replaced after it failed completely one day
Old 11th January 2017, 02:50 PM
47p2's Avatar
Normal pattern for a faulty crankshaft sensor would be that the engine would turn over as usual but fail to start.
Old 11th January 2017, 02:52 PM
sorry you're right, but does yours do that as mine is already fixed lol ?
Old 11th January 2017, 03:00 PM
Have you got the relays ? flick the lids off em and see if the points are burned and pitted
Old 11th January 2017, 03:15 PM
47p2's Avatar
The fault with mine is only when the engine is hot and only occasionally it sounds like the battery is flat or the starter motor is faulty or a bad earth or connection somewhere. Only does it sometimes so difficult to diagnose. So for the sake of a few pounds it's worth changing the relays.
Originally Posted by woodpoleman View Post
J329 is 8D0 951 253 is colour grey and has 370 on the top. J53 & J695 are part No 431 951 253G are purple and have 381 on the top. They are located behind the trim in front of the steering column. The works manual page/drawing is A97-0403 (Google it), J329 is No3 and the other two are Nos 2 & 5. J329, which carries the power was only £14.95 plus vat the other two were 31.44 each plus VAT.
Can you please confirm that all 3 relays are in the same location? do you mean under the steering column?
