Old 4th May 2021, 03:03 PM
Its rare to need to re-use the arms, so destroying them to get them out is not uncommon.
These days I tend to assume I will need to change both inner and outer tie rods in a D2 when doing control arms. The outer will usually be seized in to the upright and often in to the inner rod as well, so I remove the upright by sawing the tie rod end off and then separate the remains on the bench.
Old 14th May 2021, 06:07 PM
dangerdred dangerdred is offline
Have managed to get the drivers side done - found it a right bitch of a job tbh.
Is there any knack in getting the arch liner back in - I see the procedure mentioned in the pdf but in Rep-66 which I don't see in the downloads.
EDIT: I now see that the arch liner push trim clips are not reusable as no matter what I try I can't get them to fit back in.
Phantom Black 2008 A8 3.0 TDI SE ASB
Old 14th May 2021, 08:30 PM
S81 S81 is offline
I bought a pk of them on ebay ,how did u get the tie rod out in the end
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
Old 24th May 2021, 06:21 PM
Yeh, I'm after buying some of the rivet clips. I didn't get the tie-rod out in the end and I wasn't going to start cutting it like was suggested, so I got the arms out the conventional way by leveraging down the shock mounting plate after loosening the three bolts.
Old 16th June 2021, 04:39 AM
CrozA8's Avatar
CrozA8 CrozA8 is offline
Hi all,
I am at the point where I need to replace all of my control arms (scrubbing tyres big time) and have found this thread very interesting.
Two questions I hope you may be able to help me with.
1-Are Meyle products any good. I hear that they may not be of german quality??
2- Bushings were mentioned earlier. Can anyone let me know where I can source these, other than Audi. I'm told that Lemforder is the place to go but in Aus it's a little difficult as they seem to deal with the trade only.
Any advise greatly appreciated.
2006 A8 4.2 Ltr Silver Green 20" Factory Alloys
Old 16th June 2021, 06:25 PM
Originally Posted by CrozA8 View Post
Hi all,
I don't know anything about Meyle, I bought TRW even though I'd usually buy Lemforder parts. I still have the TRW bushes I bought (JBU138) as I wasn't able to remove the arms without damaging the ball-joints, so my complete arms needed replacing. There's a video of a guy on YT doing the bushings, but the video skips the part where he removes the ball-joints. If you don't have much galvanic corrosion and you can get movement on the ball-joints then maybe you'll fair better than I did - mine were seized solid and took a lot of brute force to get any movement at all. With corrosion, I think the only way to get them out without damaging them would be to have the whole assembly on the bench and be able to drive them out from underneath.
Old 1st July 2021, 02:52 AM
CrozA8's Avatar
Managed to get all Lemforder bushes through ZF here in Aus.
Your comments on ball joints are duly noted.
Thanks for the reply.
