Old 28th October 2010, 07:43 AM
Default Xenon/Xenon plus/Bi-Xenon
How do you tell them apart (and what is there likely to be in my 2002 S8?)?
And what's the best (practical DIY - not major refit) upgrade. Narrow B roads in the pitch black of a wet Glasgow morning are a real challenge!
Old 28th October 2010, 07:51 AM
Xenon plus are bi-xenon, same thing.
It basically means that the xenon bulb is used for both the high and low beam.
On a basic xenon, you have xenon low beam and a halogen main beam.
The xenon / xenon plus headlights are quite easy to interchange, I documented it somewhere I think.
Xenon plus:
Standard xenon / Halogen (they look identical)
The xenon plus will physically lift the bulb up when you select main beam, if you get someone to pull the light stalk whilst you're stood outside you'll see what I mean.
all Facelift S8's had xenons as standard, and on a 2002 you will almost certainly have the bi-xenon like the top photo...
HTH
Old 28th October 2010, 08:33 AM
HTH???
Yep, mine definitely look like the bi-Xenons, but I could still use a little more candle-power. Is there a simple upgrade to bulbs that might light the way a little better?
Old 28th October 2010, 09:27 AM
It means happy to help, I was thinking about this too whilst driving last night.
Could it just be that the bulbs are getting on a bit now and a fresh set will make them brighter?
I think the bulb type is D2S or something and you can pick them up for £40.
My green S8 must have had upgraded bulbs as the Bi Xenons on that were in another league to the ones I have now!
Old 28th October 2010, 09:32 AM
I think my 2.8 was better too.
Need to find some upgraded bulbs somewhere....
Old 28th October 2010, 09:47 AM
Found these
http://www.carbulbsdirect.com/bulb_f..._id=994&bulb=1
Anyone had any experience?
