D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
#31
I'm not sure what's going on with my gaby 2.8 a8 then as Im not seeing anything like what your getting in the s8's!! If I take note of the dash it says I'm getting between 10.1 and 11.6 around town and about 15-17 on a run at about 70-75? If i work it out properly im getting about 21.6-22mpg on a run! I've replaced maf sensor, all vacuum hoses, air filter, plugs. I did buy a second hand maf from Carl but he said it was all fine before I got it I have even cut out and run new wires to the maf?? I'm quickly running out of ideas and patience.
#32
I'm currently getting 15mpg around town and no better than 20mpg on a run
#33
at idle mine is telling me its using 51.9liters/100km. not sure what the issue is there.
Cat has been removed thought might be the cause. |
#34
Ouch!
My 2.8 used to average around 25mpg according to the on board computer and better on a run. As one of the real mpg saddo's, I've got nearly a year's worth of data on the S8 - every tank for around 20K miles - and it's averaging a little over 21. And I can even find data to end the arguement about getting better mpg from premium fuel (BP Ultimate, etc). You do get better mpg - about 3.5% according to my figures - but that's not quite enough to compensate for the price hike (although the 'looking after your expensive engine' arguement still holds). In effect, if you take into account the better fuel consumption, the premium fuel costs about 2p per litre more than normal fuel. I really must get out more... |
#35
![]() Quote:
#36
Watch that all too fragile ZF 5HP24 while you're at it, hehehehe.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
#37
I brimmed my tank, and zeroed the odometer. So far, as at today I've done 380.1 miles exactly. I have just under a quarter of a tank left, range is indicating 75 miles.
DIS indicates 19 - 21 mpg around town, and 26 - 30 on a long run at 70 mph. I'm curious to see what I'll get when the warning lamp comes on, and when the range is showing 0.
#38
Be careful when running down to 0 if you have not done it before and keep a can with spare fuel in boot just in case as some cars run out of fuel before reaching 0, some shortly after reaching 0 and some like mine can do another 30 miles while showing 0 and still not run out.
When I get new car I always run down to 0 and beyond as much as I dare with a can in boot just to test how far can it go to know the limit for the future. Not on diesels though as I do not fancy bleeding a system in the middle of road. |
#39
![]() Quote:
#40
Well, as at today I've achieved 402.3 miles, with a possible 35 miles indicated range. I have a jerry in the trunk, I'll put that in tomorrow. In theory, it may be possible to cover at least 20 miles more, but I'm not keen on running completely dry, and stalling on a major road.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. Last edited by Nollywood; 29th August 2011 at 05:44 PM. |
