Old 30th May 2011, 05:24 PM
FireStorm FireStorm is offline
Default Various D3 N/s Front end parts
Various bits of plastic/metal etc
part numbers as follows
4E0 121 284 C - N/S Plastic Trim Piece
4E0 129 617 P - N/S Plastic Trim Piece
4E0 121 283 D - N/S Plastic Trim Piece
4E0 129 618 Q - N/S Plastic Trim Piece
4E0 823 435 A - N/S Bonnet catch brakcet + O/S wanted but no part#
4E0 959 455 F - Rad Fan
4E0 121 207 C - Rad Fan Cowling + flippy blade things c/w ?
4E0 616 869 C - N/SBracket that holds the Compressor in? bit of metal that looks funky
4E0 806 493 03_ missing last digit but its the brakcet that holds the horn along with - Bracket 1 of 2
4E0 951 185 - N/S Bracket 2 of 2
4E0 951 223 - N/S Horn
077 109 123 F - N/S Engine cover for timing belt
Also need but no part numbers
Top N/s Pulley on the engine, its bent to hell, couldnt get part# think its the power steering as i recongise the banjo bolt at the top.
N/S bonnet cable (just the end plastic clip but dont know if you can get just that)
Sensor just below N/S headlamp just under the front panel, once again cant find part #
N/S Front Chasis Leg
N/S Lower Rad Hose
N/S Jubille Clip for power steering hose
N/S + O/S Painted Fsnished Metal bit thats just below the front of the wing that curves inwards, its not seen when the bumpers on.
N/S Bit of plastic that goes onto the front of the wing where it mounts to the bumper.
If anyone has prices of these from audi so i dont have to go in tomorrow and wait for an hour or so.
