Go Back   A8 Parts Forum > Our Other Audi Friends > Other Audis
Other Audis All other Audi related chat
Old 1st July 2016, 09:49 PM
enjoy the new (mean looking (in a good way)) toy
It is quite good fun really, and with 0-60 in 5.8 seconds is about as fast off the mark as the S8. I think the 4WD helps there. Probably no match at illegal speeds though.
The common platform with the Focus shows at times, here it is compared to a Focus RS, which is also 4WD but has an extra 100hp and a manual gearbox:
Old 9th October 2016, 04:47 PM
Having finally read the relevant section of the (online) manual properly I filled her up with "the proper stuff" today for the first time - Shell V-power.
It was heading home and only 3 miles away (1m of M25 then tiny roads), so now I need an opportunity to see if it makes a difference.
The manual actually says:
95 RON can be used for normal driving.
98 RON is recommended for optimum performance and minimum fuel consumption
Old 11th June 2018, 10:16 PM
Just a little, much later update on this.
It has been run consistently on 98/99 octane fuel since then, mostly Tesco Momentum.
More recently it's had the "Polestar Optimisation" software upgrade, which mostly increases mid-range engine torque (and power) plus changes some gearbox behaviour to make it more "sprightly" and "sporty"; and there is a Sport mode on the (8-speed auto, not 6-speed mentioned earlier) gearbox anyway if you really want to push it!
In theory fuel consumption is unchanged. But 0-100kph (62mph) is now well under 6 seconds, which is "acceptable".
