#41
Thanks for that MJ. I will check right now. I checked The Lairds 20" lower control arms this pm and.... no part number stamped on them OR makers name so that wasnt a help. My guess is that my 155 arms are the 20".
If you are still going to ADI at Castle Combe I will be there too so if you come "armed" with a pair of arms we can, perhaps come to some mutually agreeaable arrangement. ![]()
2002 D2 S8 – Ming Blue, Valcona leather, Vavona wood insert, solar sunroof (to be fitted), Heated rear seats, extended leather pack, 18” Avus, ski hatch, Bose, auto dim rear view mirror, rear blind. Last edited by Architex_mA8tey; 13th October 2016 at 10:35 AM. Reason: Changed AID into ADI :) |
#42
...and yes, the steering knuckle /hub carrier is rusty steel , hence I guess the large taper pins on the 155s I currently have fitted.
#43
Ok then. That explains the larger pins. Good
![]() The next bit of interesting info is that I have here a pair of 155P large-pin arms which I took off my B5 A4. They are dimensionally identical to the small-pin arms used on everything with alloy hubs. From that I deduce there is no difference between them, and the 'special' 20" arms are really just the same as B5, C5 and PF D2 with steel hubs. I am amazed the aftermarket haven't figured that out ![]() These are what would fit on the car I took the 155P arms off: PAIR-MEYLE-HD-Front-Lower-Forward-Suspension-Control-Arms-Audi-A4-B5-8D-1995-01 Last edited by MikkiJayne; 8th October 2016 at 04:12 PM. |
#44
Well, from what can be seen from the picture they appear to have the slightly fatter taper pin and seem to be the right part...and they are from Murrays direct where I got the others from ..and £10 cheaper (which kinda makes up for the cost of posting the others back!
I will talk to Murrays on monday. I need to get this right as I owe my garage an hours labour for taking off and re-fitting the current ones ![]()
