Old 16th March 2014, 08:18 PM
a8starr a8starr is offline
What is the procedure for removing a rear calliper? I hear you should use VCDS but how does this help if calliper is semi seized?
Old 16th March 2014, 08:56 PM
I heard you have to take the motor off and wind out the piston with a hex (allen key) bit on a drill or driver. The best thing to do is get a copy of the Audi ELSAwin official manual CDs from ebay.
Old 17th March 2014, 08:09 AM
It depends if it's the motor or the piston. The motor doesn't pull the piston in, so it still needs pushed back to change pads, etc.
You need VCDS (or an EPB tool) to tell the car to wind the motor in and then you can take it off just like a normal caliper (2 bolts).
Old 17th March 2014, 10:03 AM
Just taken car to garage this morning as I dont have the time to play around. Let's see what they say.
