Old 4th November 2020, 08:26 PM
Default Brake Block group buy
Hi all,
Per this thread, I'm pleased to offer the first home-grown brake block in water-jet-cut aluminium
This block braces the end of the master cylinder against the upper strut brace in the facelift which reduces flex in the bulkhead. The result is a firmer brake pedal and shorter stopping distance because more of the pressure from your foot ends up at the brake calipers instead of bending the body shell.
It should also fit the pre-facelift if the upper strut brace is also fitted. I believe this was only used in the PF S8, not the A8, but can be retrofitted.
<before and after vids go here>
Fitting the block requires a 13mm spanner to loosen the strut brace and philips screwdriver to remove the passenger side trim over the brace. The block slots over the brace and has a slight preload once tightened up.
There is a slight interference with the driver's side plastic cover but it still sits in place just fine
These are £30 each including UK shipping. Note these are designed for RHD cars and may not fit LHD so are only for sale in the UK (or Australia for extra shipping). Plus, they're available in the US already so not needed
There will be an initial run of 20 which should be available from ~13th November.
You know the drill...
1, Spannerrash
2, Ronin
3, The Laird
4,
5,
6,
Old 4th November 2020, 08:36 PM
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5,
6,
7,
Old 5th November 2020, 07:07 AM
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6,
7,
Old 5th November 2020, 08:44 AM
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7,
Old 5th November 2020, 09:25 AM
johnny_quattro's Avatar
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7, Johnny quattro
8,
9,
10,
Old 5th November 2020, 10:00 AM
Spanker's Avatar
Spanker Spanker is offline
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7, Johnny quattro
8, Spanker
9,
10,
Dean
Old 5th November 2020, 04:34 PM
vagdream vagdream is offline
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7, Johnny quattro
8, Spanker
9, tintin
10, vagdream
11,
________________
Cars:
2002 D2 S8 Aqua (gone but not forgotten)
1988 UR quattro
2003 A2 FSi Sport
2020 Seat Leon Cupra R ST Abt
1989 911 Carrera Cab
Couple of Mk1 Golf Gti's (in bits)
Old 5th November 2020, 04:45 PM
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7, Johnny quattro
8, Spanker
9, tintin
10, vagdream
11, CtL X 2
Old 5th November 2020, 04:47 PM
1, Spannerrash
2, Ronin
3, The Laird
4, HPsauce
5, Moltuae
6, David's8
7, Johnny quattro
8, Spanker
9, tintin
10, vagdream
11, CtL X 2
13, steamship
Old 5th November 2020, 07:52 PM
So, er, they're here already! The water jet guy was so pleased with the 'right first time' fit yesterday he knocked them out a week early
You can see the surface finish here
This is how they sit on the brace bar
Payments received (mj@d2doctor.co.uk) before 2pm tomorrow will be sent first class tomorrow Please remember to include your address in the payment note
ID:	24341   Click image for larger version
ID:	24342   Click image for larger version
ID:	24343   Click image for larger version
