Old 11th January 2019, 06:36 PM
I have a spare "hedgehog" and was planning to swap it if the problem becomes frequent.
But once or twice in 13 months doesn't qualify as frequent......
Old 6th March 2019, 01:26 PM
HVAC: 01273 - Fresh Air Blower (V2) 17-10 - Control Difference - Intermittent
Rather a wet day today but having used the car a bit recently I decided to do a scan and this error has returned. Fan working fine though... .
I still think it's probably a bad connector, maybe a poor contact affected by vibration/damp.
I wish I knew what exactly the error means, presumably something is being compared and found wanting in some way, but what sensors?
(On the plus side, no other errors apart from the eternal alarm low internal voltage warning)
Old 6th March 2019, 07:06 PM
Well, V2 is the blower motor itself of course and the Ros-Tech Wiki states:
Possible Causes
Fresh Air Blower (V2) defective
Control Module for Fresh Air Blower (J126) defective
Short of open circuit in wiring to Fresh Air Blower (V2)
Climatronic Control Module (J255) malfunctioning
Considering the motor has just two connections, the only way the controller could possibly sense something is wrong is by monitoring current-flow (unless air-flow is somehow measured, but I doubt it's that sophisticated).
So the fault code probably tells you no more than you already knew, that there is an intermittent fault causing a break in the current-flow. Probably a bad connection, as you say, but is the bad connection in the wiring, the "hedgehog" or the motor itself?
Old 4th July 2019, 08:38 AM
I haven't scanned the car since that error was spotted in March, but decided to do so today. Hasn't returned.
And the fan has been working perfectly including via Solar power.
Old 30th August 2019, 06:34 PM
Did you ever get to the bottom of this Andrew? Mine stopped working today though a sharp bang with a clenched fist on the box got it going again..so hopefully just a dodgy connection. My mechanic is going to have a look at it next week and he has Maria's number just in case
On a more positive note it passed the MOT with an advisory "Central Exhaust has a minor leak of exhaust gases"....I think it sounds better like that so not too fussed at the moment
Old 6th September 2019, 09:08 PM
No, never did. It "usually" works OK...
Old 11th September 2019, 07:31 PM
Turns out the blower motor is (to use a Scottish technical term) gubbed, managed to get the only one left from our sponsors. Came from a 2.8 so can't imagine it had a solar roof which hopefully will give me a few more years..
Old 23rd January 2020, 09:56 AM
As noted in another thread (http://forum.a8parts.co.uk/showthread.php?t=15449 ) I've decided to replace the motor anyway (with a D3 version) as it does sounds a bit "rough" at times and I'm not convinced it's running as fast as it should all the time.
And with my perennial water ingress issues I definitely need a good ventilation fan.
Old 1st February 2020, 03:23 PM
I now have my D3 motor and fan and, as noted in the other thread, the D2 lead has a circular 2-blade male plug whereas the D3 has an arch-like 2-blade female socket. See attached photos.
(It also looks like the D2 has 6.3mm blades whereas D3 is 4.8mm, though the slots will take 6.3mm..... )
Ideally I don't want to chop either lead, so does anyone have any of the following, even better with wires attached?
Option 1. A D2-style circular 2-blade male plug AND a D3-style 2-blade plug, so I can make a short 2-wire adapter lead.
Option 2. Just the D2-style circular 2-blade male plug, so I can graft this onto the D3 fan lead. (e.g. from a really dead old D2 unit, I think it's 813971956)
Also, does anyone know the part numbers of the D3 connectors (male and female)? (Edit: Looks like the male may be 1J0973852, photo added)
ID:	22824   Click image for larger version
ID:	22825   Click image for larger version
Old 1st February 2020, 05:28 PM
Given that there are no more good D2 motors so any future replacement will also be from a D3, why not graft the D3 connector on to the D2 wiring? Then the next one will be plug and play
I would get a D3 connector and terminals from TPS and splice them on to the D2 wires using heat-shrink crimps.
