Old 10th July 2012, 05:15 PM
starter motor bulge to get over
That's not starter motor bulge, it's where front diff is on side of gearbox/bellhousing. Starter motor is more towards front on side of engine and neatly tucked in not protruding at all. Must be pain in the @s# to change.
Old 16th July 2012, 06:07 PM
Hi 71camaro,
I went to the Audi dealer again today for a aircon service, whilst I was there I asked a different guy for some part numbers and prices. This time round they found a price for the cluch pedal, its not too bad. These prices are excluding VAT.
Here is the list of parts from last time with some new prices added.
Part number-----Description-----------------------Price £
4D1721401-------master cylinder----------------£231
811907343B-----clutch pedal sensor----------£16.01
4D1721465M----metal hose from master cylinder to slave cylinder---£71.50
857721453-------rubber hose supply to master cylinder-------------£10.96
4D1721485-------slave cylinder to gearbox bracket-----------------£11.24
4D1721316A-----LHD clutch pedal---------------------------------£45.85
4D1721450A-----clutch pedal spring-------------------------------£3.91
4D0721196-------spring bearing bush------------------------------£0.84
4A0721261-------slave cylinder (several different part no)---------£85
Old 16th July 2012, 10:06 PM
71camaro 71camaro is offline
That isn't bad at all. I assume that would be all parts needed? Also, I assume that "clutch pedal sensor" would be what we call the clutch safety switch? Thanks
Old 17th July 2012, 09:19 PM
I think thats most of the parts. There are a few minor bits that cost next to nothing that I forgot to ask for, they are those metal crimp pieces that hold the clutch sensor and brake pedal sensor in place.
Oh and that the other thing I forgot the brake pedal sensor.
I think you are right, the clutch pedal sensor is the clutch safety switch, I dont know what else it could be.
Old 17th July 2012, 11:47 PM
I wouldn't need a slave. I'll shoot you a PM shortly.
Old 9th October 2012, 02:20 AM
aaronkneeland aaronkneeland is offline
Did this thread die? Trying to get as much info on this swap as possible.
Old 10th October 2012, 08:16 PM
Nollywood's Avatar
Nah, it didn't die. Just working on a more pressing project, so S8 will have to wait till spring.
Old 29th October 2012, 04:30 AM
Been looking into this more of late as I'm still wanting to do it. My Bentley Manual doesn't work, can anyone get me manual trans wiring for the cruise control?
Also, anyone have access to cluster coding for manual or to stock Euro ECU tune? Easier to build the tune off that than from scratch.
Old 1st November 2012, 01:46 AM
Wooooowwwwww I apologize for what I had linked here before, obviously that isn't helping a soul.... Accidental right-click and save....
Here's the actual discussion...
http://forums.quattroworld.com/a8/msgs/73677.phtml
Here's one method of keeping cruise.
Old 8th November 2012, 05:32 AM
Bump for cruise.
How would one go that route and still have an auto-switch rear camera though?
