Old 25th February 2016, 10:40 AM
What on Earth is a main dealer doing putting mis-matched non-OEM tyres on it?! Or were they non-OEM before and they've just replaced one to get it past the AUC? Knowing how famously thorough that inspection is, naturally.....
I trust you scanned this one while you were there lol
Spec does indeed look pretty comprehensive, bar upgrade wheels.
Presume it's had the box service to schedule?
They seemed to have prepared it on a budget. Not a good sign really. The tyres are proper crap. They're round and seem to fit. That's the upside.
I didn't scan it. I simply assumed any faults would be rectified at their cost, at my local dealer. Oh boy would I look forward to that...
Box had oil change at last service....
Old 25th February 2016, 10:49 AM
Worth noting that the requirements for a sports diff equipped car wrt to evenness of tyre tread wear on the rear axle are much more stringent than the 'take average depth tread across each axle and make sure there's no more than 2mm difference in the average depth across the axle, or front to back'
ElsaWin states:
Permissible differences in tread depth
t Tyres of the same construction and tread pattern should always be used on all four wheels.
t The tyres with the deeper tread should always be fitted on the front wheels.
t It is basically possible to replace tyres individually. However, Audi recommends replacing at least both tyres on an axle at the same time.
t On vehicles with rear sport differential, Audi recommends that you always replace both rear tyres at the same time.
and also links to this which may not come out formatted correctly
Models with longitudinally installed engine
Difference in tread depth on models with longitudinally installed engines, e.g. A4, A5, A6, A7, A8, Q5, Q7, etc:
On these models, the difference between the front and rear axle must not be more than 2 mm.
Left tyre (front axle) Right tyre (front axle) Average Difference
3.0 mm 3.0 mm 3.0 mm (left to right)
Left tyre (rear axle) Right tyre (rear axle)
3.0 mm 7.0 mm (new tyre) 5.0 mm (left to right) 2.0 mm (front to rear)
within permissible tolerance range
2.0 mm 2.0 mm 2.0 mm (left to right)
4.0 mm 4.0 mm 4.0 mm (left to right) 2.0 mm (front to rear)
Old 25th February 2016, 10:51 AM
I should clarify, the tyres are all brand new, all changed at the same time for that reason, but just some wafty brand I've never heard of....
Old 25th February 2016, 12:05 PM
I thought you said 3 tyres are the same and 1 is different, surely not the way to do it if they changed all 4 at the same time.
Old 25th February 2016, 01:22 PM
Not disagreeing with you. how the hell they dredged up 3 tyres of one brand, and 1 of another, new, is questionable indeed.
But, crucially, all new, so all 4 changed at same time, and all same tread depth, for about two minutes until a really, really cheap one wears faster than the really cheap one...
Old 27th February 2016, 06:12 PM
No way, Ian. I've always found the S5 Cab such an anti-climax to drive, but I assume you drove it if you travelled all that way. If I were you, I'd buy a B7 RS 4, you'll still release capital, and have a fun car to drive - and available as a cab.
Old 28th February 2016, 05:15 PM
Well, that would be the nail on the head.......
Lucky guess? Or clever deduction ?
WOW....I didn't realised that this middle life crisis is so severe
Sorry
On a serious note, there is something about the cabrios and the wind in the hair. I do like them but in Coupe only, but thats about it. Sorry
For me there are two things which put me off:
- handling as mentioned earlier
- the dash which reminds me very much A6s and Q7s which is dislike a lot only because of that hence I wouldn't own one, interior feel is very important to me, same as exterior and driveability.
But, this has been mentioned hundreds of times on the forum, all what matters is what you like and want, we can only chip in few pence and that's about it.
I do like them in black, quad exhaust and spec
I hope it all goes well with RS6 and you won't have to do the black friday discount as this car is well worth the money !!!
Good luck Ian
Old 28th February 2016, 07:31 PM
roberto's Avatar
roberto roberto is offline
i drove an S4 avant that was remapped yesterday
59 reg so is that a b7 ?
3.0 supercharger or something
i was very very impressed.. £16,500
Old 28th February 2016, 07:40 PM
That's the B8 and if an auto it's s-tronic dual clutch
Depending on the map you can gain almost 50% on stock power but fuel consumption is pretty horrid even when stock! Fuel tank is tiny on them too...
Seem to fill our S5 Sportback every 200 miles
Old 28th February 2016, 07:44 PM
After a year on nagging, I managed to get my mate to buy B7 RS4 57plate, £22k
What a car !!!!!!!
Juicy and a bit outdated, but in all honesty if my choice was narrowed down to two cars only in same price range, this S5 and older RS4 then there is only one winner.
But looking from Ian's point of view, if it's same money so no savings on the initial purchase, maybe few k's if not bothered with less mint car, RS4 isn't the most economical car so kind of missing a point here.
But another but is that I can't see S5 being that much more economical than RS4
