VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Just got a Vag run on the new beast. Any comments welcome. Particularly in regards to reseting the leveling stuff as getting the headlights level and not very short would be great at this time of year!
Wednesday,20,January,2016,13:18:27:05031 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86 VCDS Version: 15.7.1.0 Data version: 20150904 www.Ross-Tech.com VIN: WAUZZZ4E65N014192 License Plate: GO02CAT Mileage: 215800km-134091mi Repair Order: Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 15 16 17 19 1E 25 28 34 36 37 38 42 46 47 4F 52 53 55 56 57 61 62 69 72 76 77 VIN: WAUZZZ4E65N014192 Mileage: 215800km-134091miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: Malfunction 0010 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: Malfunction 0010 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: Malfunction 0010 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 1010 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door, Rear Left -- Status: OK 0000 69-Trailer -- Status: Malfunction 0010 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 077-910-560-BFM.lbl Part No SW: 4E0 910 560 Q HW: 4E0 907 560 Component: 4.2L V8/5V G 0030 Revision: 00000000 Serial number: AUX3Z0DD356295 Coding: 0011773 Shop #: WSC 00000 000 08192 VCID: 2F6A8B93BE0EEB46F4-807A 4 Faults Found: 16814 - Catalyst System; Bank 2 P0430 - 002 - Efficiency Below Threshold - MIL ON 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - - Intermittent 17819 - Secondary Air Injection System; Bank 2 P1411 - 002 - Insufficient Flow Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E0 910 156 S HW: 09E 927 156 A Component: AG6 09E 4,2L5V RdW 0020 Revision: --H01--- Serial number: 0052057 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 326C82E7AD3CC6AE9B-8066 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008597 Shop #: WSC 00640 000 00000 VCID: 224C72A7FDDC562E6B-8076 1 Fault Found: 00526 - Brake Light Switch (F) 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0DD356295 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B8104FEB00CCFE45-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX 2 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 233 Mileage: 214544 km Time Indication: 0 Date: 2015.12.10 Time: 20:35:28 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 232 Mileage: 214624 km Time Indication: 0 Date: 2016.01.14 Time: 19:58:14 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 00000 785 00200 VCID: 234277A3E2C65F2660-8076 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300AH057548066 Coding: 0000002 Shop #: WSC 00000 000 00000 VCID: 3A7CAAC7754C3EEE53-806E Subsystem 1 - Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 Subsystem 2 - Serial number: 318AD057515140 Subsystem 3 - Serial number: 7419.01.0500000000218B0050˙ Subsystem 4 - Serial number: 8B0050˙ 1 Fault Found: 00003 - Control Module 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 01100101 Fault Priority: 5 Fault Frequency: 1 Reset counter: 178 Mileage: 214553 km Time Indication: 0 Date: 2015.12.10 Time: 19:48:29 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 A HW: 4E0 820 043 A Component: KLIMAAUTOMAT 016 0340 Revision: 00000029 Serial number: 00000000059730 Coding: 1069073 Shop #: WSC 02311 785 00200 VCID: 1B324F43DAB667E6A8-804E 3 Faults Found: 00065 - Rear Left Footwell Heater (Z42) 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 29 Reset counter: 183 Mileage: 200260 km Time Indication: 0 Date: 2015.06.06 Time: 14:06:10 Freeze Frame: Voltage: 11.30 V 00066 - Rear Right Footwell Heater (Z43) 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 254 Reset counter: 232 Mileage: 200261 km Time Indication: 0 Date: 2015.06.06 Time: 14:14:10 Freeze Frame: Voltage: 12.80 V 01858 - Air Outlet Sensor; Right Center (G348) 010 - Open or Short to Plus - Intermittent Freeze Frame: Fault Status: 00101010 Fault Priority: 3 Fault Frequency: 2 Reset counter: 221 Mileage: 214574 km Time Indication: 0 Date: 2015.12.12 Time: 22:25:23 ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H12 0210 Coding: 0120121 Shop #: WSC 02313 785 00200 VCID: 316E8DEBA83AFDB6E2-8064 Subsystem 1 - Part No: 4E2 910 113 B Component: Wischer WWS D3 H50 0420 Coding: 00000036 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.lbl Part No SW: 4E0 910 655 HW: 4E0 959 655 G Component: Airbag 8.4E+ H10 0940 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 63C237A3A2461F2620-8036 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0112141 Shop #: WSC 02311 785 00200 VCID: 65C629BBAC726116CE-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 950 H HW: 4E0 920 950 H Component: KOMBIINSTR. VDO H53 0200 Revision: D05 Serial number: AUDID3E0000050 Coding: 0000404 Shop #: WSC 00443 067 57207 VCID: 295E658B80EA85762A-807C No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 4E0-910-468.lbl Part No SW: 4E0 910 468 HW: 4E0 907 468 A Component: Gateway H07 0070 Revision: 07 Serial number: 16003049161CE4 Coding: FDFE7FDC2B3504 Shop #: WSC 00640 210 83262 VCID: 65C629BBAC726116CE-8030 1 Fault Found: 01771 - Control Module for Headlight Range (J431) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 3 Reset counter: 229 Mileage: 215417 km Time Indication: 0 Date: 2016.01.18 Time: 16:24:55 ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 111 F HW: 4E0 035 111 A Component: CD-Changer H44 0470 Revision: 00000000 Serial number: AUZ5ZBD7106789 Shop #: WSC 00000 000 00000 VCID: 1C304C5FDFB860DEA1-8048 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 C Component: FBS AUDID3 H04 0140 Revision: 01404004 Serial number: AUX3Z0DD356295 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B8104FEB00CCFE45-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 2 Faults Found: 00191 - Passenger's Door Handle Touch Sensor (G416) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 14 Reset counter: 233 Mileage: 214544 km Time Indication: 0 Date: 2015.12.10 Time: 20:35:28 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 2 Reset counter: 232 Mileage: 214624 km Time Indication: 0 Date: 2016.01.14 Time: 19:58:14 ------------------------------------------------------------------------------- Address 28: HVAC, Rear Cannot be reached ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015520 Shop #: WSC 67148 512 1446452 VCID: 2A5C9A8785EC8E6E23-807E 4 Faults Found: 01583 - Leak in System Detected 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 3 Fault Frequency: 4 Reset counter: 233 Mileage: 214615 km Time Indication: 0 Date: 2016.01.14 Time: 17:21:14 01437 - Control Position not Learned 005 - No or Incorrect Basic Setting / Adaptation Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 178 Mileage: 214553 km Time Indication: 0 Date: 2015.12.10 Time: 19:48:30 01400 - Suspension Level Control 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 22 Reset counter: 232 Mileage: 214555 km Time Indication: 0 Date: 2015.12.10 Time: 20:49:39 01772 - Signal from Level Control Pressure Sensor (G291) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 16 Reset counter: 233 Mileage: 214563 km Time Indication: 0 Date: 2015.12.11 Time: 18:15:27 ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063338 Shop #: WSC 00000 785 00200 VCID: 234277A3E2C65F2660-8076 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 C Component: MNS ECE H44 1060 Revision: 00000000 Serial number: 305AK057565443 Shop #: WSC 00640 210 83262 VCID: 3B72AFC37A7607E648-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H02 0090 Serial number: 00000429500044 Coding: 0035972 Shop #: WSC 02313 785 00200 VCID: 1D36415BC4A269D656-8048 5 Faults Found: 00215 - Control Circuit for Reading Lights Rear Right 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 181 Mileage: 214584 km Time Indication: 0 Date: 2015.12.29 Time: 00:21:00 00214 - Control Circuit for Reading Lights Rear Left 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 181 Mileage: 214584 km Time Indication: 0 Date: 2015.12.29 Time: 00:21:00 02140 - Control Circuit for Left Front Makeup Mirror Light 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 181 Mileage: 214584 km Time Indication: 0 Date: 2015.12.29 Time: 00:42:00 02282 - Sunroof Drive; Obstruction Detection 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 222 Mileage: 214592 km Time Indication: 0 Date: 2016.01.06 Time: 18:00:00 02141 - Control Circuit for Front Right Makeup Mirror Light 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 184 Mileage: 214688 km Time Indication: 0 Date: 2016.01.14 Time: 22:33:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 B Component: Türsteuer.FS BRM002 0060 Coding: 0000512 Shop #: WSC 02311 785 00200 VCID: 204878AFF3D0443E7D-8074 1 Fault Found: 02110 - Window Regulator Switch 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 0 Reset counter: 196 Mileage: 213968 km Time Indication: 0 Date: 2015.11.12 Time: 23:41:20 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.lbl Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Revision: 00400004 Serial number: W040412200010 Coding: 0004345 Shop #: WSC 02313 785 00200 VCID: 275A63B396FEB3063C-8072 Subsystem 1 - Part No: 4E0 910 853 Component: Heckdeckel H06 0050 Subsystem 2 - Part No: 4E0 907 719 Component: Neigungssensor H03 0020 5 Faults Found: 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 67 Reset counter: 192 Mileage: 214555 km Time Indication: 0 Date: 2015.12.10 Time: 20:49:35 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 13 Reset counter: 232 Mileage: 214577 km Time Indication: 0 Date: 2015.12.12 Time: 23:02:38 00892 - Switch for Trunk Closing Cylinder (F248) 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 3 Fault Frequency: 36 Reset counter: 229 Mileage: 214581 km Time Indication: 0 Date: 2015.12.18 Time: 20:14:08 01699 - Motor for Central Locking; Hatch/Trunk (V53) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 3 Fault Frequency: 1 Reset counter: 229 Mileage: 215417 km Time Indication: 0 Date: 2016.01.18 Time: 14:33:15 01565 - Luggage Compartment Light (W3) 009 - Open or Short to Ground - Intermittent Freeze Frame: Fault Status: 00101001 Fault Priority: 3 Fault Frequency: 3 Reset counter: 229 Mileage: 215417 km Time Indication: 0 Date: 2016.01.18 Time: 16:12:27 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 P HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0460 Revision: PROD_01 Serial number: 00000000009844 Coding: 0000017 Shop #: WSC 02313 785 00200 VCID: 2A5C9A8785EC8E6E23-807E 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 233 Time Indication: 0 ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Revision: Serial number: 00000000054576 Coding: 0010101 Shop #: WSC 02313 785 00200 VCID: 1E344657C9A472CE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 B Component: Türsteuer.BF BRM002 0060 Coding: 0000512 Shop #: WSC 02311 785 00200 VCID: 204878AFF3D0443E7D-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Revision: AV1C1010 Coding: 0000531 Shop #: WSC 00443 210 85062 VCID: 1D36415BC4A269D656-8048 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4E0-910-357.lbl Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Revision: 00000001 Serial number: Coding: 0000001 Shop #: WSC 02311 785 00200 VCID: 62CC32A7BD5C162E2B-8036 1 Fault Found: 01310 - Level Control System Control Module (J197) 013 - Check DTC Memory - Intermittent Freeze Frame: Fault Status: 00101101 Fault Priority: 2 Fault Frequency: 0 Reset counter: 40 Mileage: 214552 km Time Indication: 0 Date: 2015.12.10 Time: 20:32:27 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396AO057503292 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316E8DEBA83AFDB6E2-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: 4E0-910-146.clb Part No SW: 4E0 910 146 G HW: 4E0 919 146 C Component: TV analog TUNER H14 0300 Revision: 00000013 Serial number: 00000000001651 Coding: 0000003 Shop #: WSC 00000 785 00200 VCID: 254669BBECF2A1160E-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: ENERGIEMANAGER H12 0390 Revision: 00000000 Serial number: 00000000000611 Shop #: WSC 00001 210 58515 VCID: 204878AFF3D0443E7D-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 1501170013 Coding: 344530393135313035412056413031353031313730303133 Shop #: WSC 00000 128 00289 4 Faults Found: 02273 - Quiescent Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 214585 km Time Indication: 0 Date: 2016.01.06 Time: 17:20:29 02276 - Quiescent Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 214585 km Time Indication: 0 Date: 2016.01.06 Time: 17:20:40 02274 - Quiescent Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 214585 km Time Indication: 0 Date: 2016.01.06 Time: 17:20:50 02277 - Quiescent Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 1 Reset counter: 255 Mileage: 214585 km Time Indication: 0 Date: 2016.01.06 Time: 17:21:00 ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 1E344657C9A472CE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 69: Trailer Labels: 4E0-910-383.lbl Part No SW: 4E0 910 383 C HW: 4E0 907 383 C Component: ANHAENGERELEKTR 004 0060 Coding: 0000001 Shop #: WSC 00000 000 00000 VCID: 244074BFE7C8581E19-8070 1 Fault Found: 00526 - Brake Light Switch (F) 008 - Implausible Signal - Intermittent Freeze Frame: Fault Status: 00101000 Fault Priority: 3 Fault Frequency: 15 Reset counter: 232 Mileage: 213852 km Time Indication: 0 Date: 2015.11.10 Time: 16:39:00 ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0028462 Shop #: WSC 02311 785 00200 VCID: 1E344657C9A472CE4F-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Revision: --.--.-- Serial number: 08720501302926 Coding: 0001008 Shop #: WSC 02313 785 00200 VCID: 214E7DABF8DA4D3672-8074 1 Fault Found: 01547 - Sensor for Parking Aid; Rear Mid-Right (G205) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 17 Reset counter: 188 Mileage: 214553 km Time Indication: 0 Date: 2015.12.10 Time: 20:32:23 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-333.lbl Part No SW: 4E0 910 333 F HW: 4E0 862 333 C Component: TELEFONMODUL EU 0770 Revision: 00000006 Serial number: T2AUDX0505HJ01 Coding: 0000004 Shop #: WSC 02313 785 00200 VCID: 224C72A7FDDC562E6B-8076 No fault code found. End-------------------------(Elapsed Time: 04:10)-------------------------- |
There seems to be a lot of failures in there. Have you cleared down all error codes (Clear DTCs) and then rerun the auto-scan to get an accurate picture of the state of the car?
Lee 2017 Nissan Leaf Tekna |
A number of the codes look like the normal transient power blips. The rear footwell heaters are a common failure in D3.
As Lee says.. clear them down and see what comes back.
