Old 17th May 2018, 06:03 PM
Chip2786 Chip2786 is offline
Question RSE PLayStation 2/ PS2 conundrum
Has anyone else got a PS2 in the boot that plays through the Rse TV’s?
Only the Right TV currently powers on so I had the boot apart earlier trying to find out why, I found 20meters of Composite cables wrapped up, a small box with most of the sticker missing but what I could read said ‘PS2 adapter’ and a lot of chopped and soldered cables.
From what I gather they have tapped into the DVD changer cable for picture and audio (which may explain why the DVD doesn’t eject or power up)
My questions are
1. Does that sound like a normal PS2 install
2. Where is the original RSE controller, would it still be installed?
3. There are 2 retrofitted add-a-fuse adapters in the front left (passenger) fuse box, I unplugged 1 of the and the PS2 and right screen powered down. I unplugged the other fuse and nothing happened? what could that power?
TIA Dudes
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 18th May 2018, 07:46 AM
The D3 never had a factory, or dealer fit playstation option, just a DVD changer in the left hand side of the boot and screens in the headrests.
I believe all the factory RSE kit sits with the AV stack in the left corner of the boot.
Old 18th May 2018, 08:09 AM
Ok well it’s not in there so I presume the RSE is also retrofitted. Thank you for the reply
Jobs done so far;
Tags
ps2, rear seat entertainment, rse
