Old 8th June 2019, 01:43 PM
Chip2786 Chip2786 is offline
Default RS Flat Bottom Steering Wheel fitted!!
So I just finished fitting a Flat Bottom RS wheel to the S8, I was pretty worried because no one seems to have done it (or at least posted about it) before.
I know its not everyone's cup of tea but I've always liked them, heres what I did
Difficulty 4/10 (fairly easy)
Time about 1.5 Hours for me but you could easily do it in 40 mins with this guide
Step 1. Remove the battery negative terminal If you like your face where it is DO NOT SKIP
Step 2. I followed the 1st part of this guide to remove the old airbag, keep the old wiring loom because the RS loom has a different fitment.
Step 3. I used the above guide to help me remove the wheel bolt using this from amazon
and this from a local shop
you will have to fight yourself to get the bolt to budge as the steering lock cannot be engaged
Step 4. Fit the new Wheel, It has guiders so it will only fit on 'straight' make sure the wheel bolt is very firmly tightened
Step 5. Here comes the reason why it took me so long, The Airbags spade connectors are different size's between the S8 and the RS3 so when I connected it up fist time the horn was continuously on (sorry neighbors)
This connector looks like a normal ground but it is in fact the horn contact, I had to (with a small flat screwdriver) peel the small spade connector open enough to fit over the RS airbags bigger terminal
I did the same thing for the proper ground pin
Step 6. Fit the new airbag carefully making sure you don't snag any of the cables and screw it back in from behind
Step 7. (Optional) I removed the S8 Badge from my wheel and fitted it to the RS wheel. It was easy to remove the badge from the S8 wheel because its made of leather around the badge, The RS is plastic so I dented the wheel whilst doing it, its not the end of the world just worth noting
Everything works as expected, all buttons work and the flappy paddles do too! im very happy overall
Jobs done so far;
Fitted an RS Steering Wheel, Fitted 15mm wheel spacers, Lowered 10mm with VCDS, Reinstalled factory DVB, Unlocked VIM, Updated MMI to 5570, Fixed Factory Bluetooth Phone, Fitted heated fan-spray washers, Installed Bluetooth DAC For Audio, Added projection Puddle lights, Wind Deflectors, Fitted Apple TV to all 3 Screens, installed car WiFi, Fitted Custom vortex Exhaust
Old 8th June 2019, 02:18 PM
Johnmed's Avatar
Johnmed Johnmed is offline
Nice work. Are the airbags both of the same type? I know some are single stage etc.
I replaced my wheel and airbag with an S8’s, gaining paddles.
2007 Mini Cooper S R56
Old 8th June 2019, 02:30 PM
They are both dual stage airbags so no error codes on the dash
Jobs done so far;
Johnmed's Avatar
Happy days.
Old 8th June 2019, 03:05 PM
homer simpson's Avatar
I like that very much! What year RS3 wheel fits the D3? I wonder if there was a heated version.
Old 8th June 2019, 03:24 PM
I didn’t go by year in the end (it’s a minefield) I just bought a wheel that had the same spec as my original (flappy paddle, volume, mode button, voice assist etc) there are a lot of newer wheels that have more buttons but I’d avoid as they will be wired differently
Jobs done so far;
Old 8th June 2019, 06:03 PM
Norretal's Avatar
Norretal Norretal is offline
Nice work Chip, your mods are inspiring me
Audi TT - 2015 - Ultra
Old 10th June 2019, 07:46 AM
As far as i'm aware, there are no heated flat bottom wheels....
Every brochure, even for modern cars, you can opt for flat bottom _or_ heated but never both.....
Old 10th June 2019, 07:50 AM
Its all a data bus for the multifunction wheels. Paddles, heating control, illumination and buttons all travel down a single data bus usually.
Only the horn and airbag have dedicated wires in the slip ring from memory. Heated wheels have a pair of heavy duty brushes around the slip ring to conduct the current.
I don't know what protocols are used between the later cars though, so if that's changed, it could be game over, but I suspect wiring will be surprisingly similar.
Old 10th June 2019, 02:02 PM
Damn! I remember looking through the D3 brochure and there were certain options that were not available in sport (S8) spec like heated steering wheel and massage seats. Why Audi, why??
