Old 10th October 2015, 12:53 PM
voicey voicey is offline
Default Updated Nav Disc
Can anyone help me with an updated Nav disc? I have recently bought a new to me D3 but only have a 2007 disc.
Cheers....
Old 10th October 2015, 02:32 PM
There's a thread about 2015 Nav Discs in the D3 section.
Matt
Old 10th October 2015, 04:21 PM
In case that's a bit cryptic you can find the latest version here
http://a6retrofit.com/mmi-2g-navigat...d-europa-2015/
If you don't do torrents or can't be arsed with burning the disc yourself (good quality media and slow burn speed generally work OK for 2G discs) then myself and a few others around the place can produce you one for a few beer tokens
Adrian
Old 10th October 2015, 04:46 PM
Thanks. I've haven't used torrents for years but I'll give it whirl!
Old 10th October 2015, 09:41 PM
Johnmed's Avatar
Johnmed Johnmed is offline
I used that site for my 2014 and 2015 nav discs. Can't fault them. Follow the guide to the letter and you'll be golden
2007 Mini Cooper S R56
Old 11th October 2015, 12:25 PM
Thanks guys - I'm all updated now (MMI firmware and 2015 maps).
Is there any way of enabling full postcode search? Seems a bit silly to have to enter the first part and then the street!
Old 11th October 2015, 12:41 PM
Johnmed's Avatar
Would be great to add that functionality, and speed cameras too. I know it's possible, with a tweak on the RNS E units or whatever they're called.
Edit, here's the link to full 7 digit post code entry and speed cams database for the later RNS-E head units. I'd like to think it was possible on the D3 A8s too... Even if it isn't, maybe it will be of use to those with D2s?
http://www.a2oc.net/forum/showthread...e-on-the-RNS-E
Old 11th October 2015, 01:24 PM
I didn't think you can get full 7 digit sat Nav input unless you've got MMI 3G later systems
