Old 18th April 2013, 08:52 PM
We do some, nothing arranged at the minute specifically for '8s, but the audi-sport guys have some now and again, and are a welcoming bunch.
Where in Scotland are you, a few of us have VCDS and could help out.
Old 19th April 2013, 12:23 PM
Ocho Ocho is offline
Thanks for the info, I'm in Peterhead, just north of Aberdeen. I've ordered the towbar but it wont come until mid next week, and then I need to fit it, that'll take a day or two.
Old 20th April 2013, 12:24 AM
Originally Posted by Ocho View Post
Can you point me to the correct codes to use for coding the towbar??
Assuming you have also bought the Westfalia wiring kit then the install instructions are availablehere.
Have a look at page 32, you need to code the following modules:
01 Engine control unit
13 Distance control ACC
19 Diagnosis interface for data bus
34 Level control
45 Brake electronics ESP
76 Park distance control
Assuming you have a full version of VCDS there is a coding helper for each of those modules, you need to add the towing/trailer option to each. It's all pretty simple once you have it in front of you
Old 20th April 2013, 07:44 PM
Thanks paulrstaylor your info is great.
Old 2nd January 2016, 12:44 PM
Johnmed's Avatar
Johnmed Johnmed is offline
To revive an old thread...
Hi. Help!
I'm still after a towbar for my D3. I've found one second hand, but the seller assures me this all that is needed, see pic, and all A8s are wired to accept this.
I'm of the opinion that a loom/controller/etc is needed to interface between the Towbar and the car.
I'm utterly confused at this point, but really want a towbar, and can't justify the cost of a new one.
Thanks. John.
2007 Mini Cooper S R56
Old 2nd January 2016, 02:21 PM
harvmiester17 harvmiester17 is offline
You can fit that tow bar and use standard single or twin electric sockets. All you need to do then is put the car in towing mode manually. I did this with mine using an original Audi tow bar and it all works perfectly. It's also handy having the battery in the boot for the wiring. You will need a 7 way bypass relay for the lights which will prevent any issues with the cars lighting system but it's a doddle to fit.
Old 2nd January 2016, 03:06 PM
Johnmed's Avatar
Cheers for that. Food for thought.
Old 2nd January 2016, 06:55 PM
Johnmed's Avatar
Do you have a part number for the swan neck towbar detachable bit? I've just bought the towbar frame (sans electrics and swan neck towbar).
I'm intending to get the bits together as and when, and get around to fitting it in the spring/summer/when I have time and it's not cold,.. or raining...
