#31
Thank you so much. I only did a one stage. I would have never known that. I'll do that tomorrow morning and hopefully all will be well. Will report back tomorrow. Thanks again. |
#32
All done. Im now on version 1110. As per your advice Julian I just had to go round a second time. Next its onward to 5570.
#33
sorry didnt get back to you have been in thomasland with the kids and only my phone to work on.
glad you got it working, i had no idea about the running it twice, thats a good find from Julian. As i said if your bluetooth is still working fine, update cd1 on 5570 and you shouldnt have a problem with CP then you should be able to do the tweaks to get the AV1 and 2 in as well as the hidden menu.
______________________________________________ A8 4.2TDI - Ice Silver, Comfort heated/cooled/massage Seats, Alcantara, Extended Leather pack, Ambient light pack, Solar roof, Night Vision, Lane change assist, Audi presense, Audi BrakeGuard, ACC Cruise, Blinds, Quad Air, AMI, Online services, Parking with rear Camera, Aluminium brushed inlays, Adaptive Zenons, High beam assist, Bose Sound, and more Gone but not forgotten: A8 D3 2005- AMI HDD, Audible Parking, TV, NAV, Bluetooth, Hybrid TV, Aftermarket headrest monitors, Rosstech VCDS / Vagcom |
#34
No worries. I really appreciate all your help and advise. I notice now on source>AV I get Av1 and Av2 which is great! Ill do 5570 next. So do you recommend I only do disc 1 or should I do all three CD's? |
#35
if you do disk 2 you are very likely to get CP kick in and you will notice that only one side of your amp is working until you get CP removed at an audi dealer.
try your blutooth now, if its still working fine then just do disk 1
#36
Whats CP? If I skip disc 2 is it worth doing disc 3? What does 3 give me? |
#37
Component Protection.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
#38
You shouldn't get CP on a valid 'been in the car since new' ECU but a bug in the firmware for the Bose amp puts CP on when it shouldn't. =============================================== limoncello; sorry, but you've got your CD numbers mixed up. I have the 'proper' CDs from the 3CD set in front of me and I've looked at them in my CD drive. CD1 is the MMI update to go to 5150 - no BT updates on this. CD3 is the MMI update to go to 5570 - no BT updates on this. CD2 is the BT update disk to go to 1130 on the BT phone - no MMI updates other than that on this. If you want to leave BT 'untouched', run CD1 until you get no updates then run CD3 until you get no updates. You'll then be at 5570. HOWEVER, both CD1 and CD3 contain the updated Bose firmware level 460 which may put the amp into CP Julian
Audi A8 3.0TDi MY2016 in Nautilus Silver. Audi A8 3.0TDI MY2005 in Midnight Blue. Gone since 2018, after 10 years! |
#39
I would suggest you try that again first with the MMI level at 1110 to see if that's fixed it - as was hoped. Then I'd go on to update the MMI to 5510/5570. Julian PS I see you have said you have a BT module on order. Until you install that, CD2 [BT updates] won't do anything as it won't find any matching ECUs. I would install the BT module and check its level before trying CD2.
#40
Thanks again
I installed CD1 and gone to 5150. I noticed that the battery level function from car>systems has gone which is a shame as I liked that. When I mentioned Bluetooth I wasnt referring to an OEM audi unit. Im going to feed BT through Aux inputs using Av1.. |
