Old 30th April 2016, 09:11 AM
goldsax goldsax is offline
thanks for the replies..
its and SE spec.
looking at the 2006 brochure, 2 options
1) 8.5J x 18 ‘5-arm’ design high-gloss alloy wheels
with 255/45 R18 Y tyres
2) 8J X 18 ‘9 spoke’
with 235/50 R18 Y tyres
what ET would i need?
i presume the second option would be the most comfy...any disadvantages?
i bought the 4.2 due to its power/torque, would it be wasted with 235 tyres? at which point the 255 may be considered?
thanks again for the input..
raj
Old 30th April 2016, 09:15 AM
Johnmed's Avatar
Johnmed Johnmed is offline
My SE 3.0 has 17"s with a 235 and 55 profile on. And I'm currently in the process of buying 19"s with a 255 and 45 profile. I drove a sport with 19"s on before I bought my car, and found it rode a lot better oddly. So I'm interested to see how mine will ride with 19"s. If it's harsh I guess I'll be using comfort more often than now, which is pretty much never.
2007 Mini Cooper S R56
Old 2nd May 2016, 09:01 AM
audifin audifin is offline
ET for 8.5J wheels is 45. I have the 18" 12-spoke wheels, they are not on 2006 brochure (only 19"). Not sure if they were available before or after 2006?
As it happens there is a refurbished set on ebay at the moment http://www.ebay.co.uk/itm/Genuine-re...gAAOSw2GlXG~zO
My tyres are 255/45/18. Difference in the profile height is marginal compared to 235/50 so I wouldn't think there is much difference in comfort.
Old 2nd May 2016, 09:19 AM
Burnzybubbles's Avatar
Try fitting a 45 profile tyre on your 19's it should make them less solid, I have a 45 profile on mine, the speedo is spot on now too.
Old 2nd May 2016, 09:01 PM
had a look at the front disc.
there is about an inch between the wheel and disc.
so there is no way a 17” is going to fit.
18 or 19 it is then
thanks for the link re. the 18” .
interesting idea re. 255/45 R19 tyres. and as mentioned does not mess with speedo may opt of this option in the next couple weeks
will keep updated..
thanks
raj
Audi S8 2002
Old 3rd May 2016, 05:57 PM
18 or 19 it is then
will keep updated..
thanks
raj
255/45/19 and 255/40/18 have the same circumference, and 255/45/19 is bigger, so that's the one that will "mess" with speedo, i.e. instead of showing a few % more than actual speed it would be spot on
Old 11th May 2016, 08:18 AM
following another thread :
http://forum.a8parts.co.uk/showthrea...t=11571&page=4
i reduced pressure to
front 35
rear 30
wow what a difference.
that skittish feeling has gone and the car now drives smooth and with reduced tire roar.
how on earth you can get a smooth ride with a pressure of 40 on the rear is beyond me.
to push the boat out, i am getting a set of 255/45/19 over the weekend. i am sure it will be even smoother.
Audi S8 2002
Old 11th May 2016, 12:12 PM
As with the other thread i'v just posted in, when was the last time you had a proper 4 wheel alignment done?
I run 40psi all round and have never even had the slightest skittish feel, my car was aligned on a hunter machine about 12 months ago and I haven't done anything to knock it out yet so it should still be Bob on.
Old 11th May 2016, 12:16 PM
thanks for the suggestions re. alignment.
i will get that done that done this weekend when i get the new tires on.
Audi S8 2002
Old 11th May 2016, 12:59 PM
Johnmed's Avatar
I know the question wasn't directed at me but to add, I had my geometry checked about a year ago. It was spot on and only got charged half the fee cos no adjustment was needed. (Mine feels a little skittish with 37 and 40 PSI on 19s)
