Strength no issue, there is a huge safety factor in them i'm sure. Just look at it. Or lay it down next to the jack. I reckon you could pick the whole car off the ground with the tow bar
However, Dezzy, the manual (who reads that!) states in bold that the maximum vertical force should not exceed 95kg. So i guess the towbar fixings are designed to accept 2300kg (+safety margin) in a fore and aft direction but only around 5% of that in the vertical. Therefore two average adults would exceed the designed max load though there wont be too much dynamic loading unless..... i dont want to even imagine that
95kg is the static nose weight, when your doing 70mph and bounce over a pothole with a trailer hitched I'd imagine that would increase significantly momentarily.
So long as you don't use your hammock at speed I don't think you will do any harm |
I was meaning the location of the weld may compromise strength and the "safety factor"
Obviously as soon as you do weld it you'd loose all manufactures type approval. I'd be happy sat on that put it that way, although one thing i would do is radius those corners with 10mm rad min. If you were to shin one of those it would hurt...... for hours
did anyone try this????
Audi V8 Quattro Original 5speed - Black/Black Audi S8 - Avus/Oxblood Audi S8 - Cashmere/Twist BMW 850i - Red 6speed BMW 850Csi - Red 6speed Ford Thunderbird x 3 Supercharged & 5speeds Mustang convertible Range Rover Autobiography - BRG/English Tan |
