Not looking good
Unless it's "just" the F125 switch.....
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Argh That's usually something slipping, and that is usually the front broken off the front clutch drum.
Assuming you don't fancy a full rebuild, replacing the clutch drum is DIY'able if you're able to get the gearbox out. Its available new from ZF dealers, or you could use a donor gearbox, although that's a risk that it also has a cracked drum. Prestige have a dead one in at the moment I think, although I don't recall what the fault was. |
Problem appears to be with 1st gear. Moving off it makes a jolt and switches to 5th. If I manage to manually switch to 2nd before fault occurs it works fine until goes in 1st again.
Any idea what the solenoid current should be? Most are 0.144A but one is 0.742A?
Also strange that fault code says Gear 3 but problem seem to be with 1st.
Unless it's a solenoid or something else I can DIY from under the car without removing the box I am afraid it will be the end of S8.
This is what Elsa say
Currently 8less 2011 Q7 S Line 3.0TDI, 2016 Tesla Model S 90D 8 history: 2006 A8 Sport 4.2TDI quattro SOLD, 1997 S8, reached end of life with gearbox failure Last edited by ainarssems; 24th August 2019 at 05:25 PM. |
As soon as I move off, jolt and fault code registered for gear 3 when it's only been in 1st, if I manage to get to 2nd all other gears work fine including 3rd until it selects 1st again.
Ffs ainars, must be save able on a shoe string.
Just out of interest what happens when the 4 speed is coupled to the S?
