Old 6th January 2020, 04:59 PM
homer simpson's Avatar
If you've got an adaptive cruise widescreen cluster then you wont get the digital speedo as well as apparently it needs to be able to use a "vacant" screen display option to show the distance between vehicles you've selected and the digital speedo was the one they chose to replace.
I know this because I've already replaced my cluster with an adaptive cruise one and had the same question as to why it had disappeared!
I have a facelift with adaptive cruise and I have both screens. Perhaps a coding issue?
Originally Posted by dangerdred View Post
Thanks for that. I must have pressed this before and when I saw it didn't seem to do anything I never went back to it - two presses brings up the digital speedo. Is there meant to be some function to the first press?
The first two look the same but do show different readings at the bottom. I think they are average MPG and live MPG but I culd be wrong without checking.
Old 7th January 2020, 08:14 AM
I have a face-lift with adaptive cruise and I have both screens. Perhaps a coding issue?
My car is an early face-lift model - is yours the later facelift model?
It may possibly be because until I have fitted the adaptive cruise widescreen dash but had to currently still code it as the standard widescreen dash to ensure the standard cruise control still works until the rest of the adaptive cruise kit (which I now have) is fitted
Old 7th January 2020, 10:58 AM
Mine is a 2008 so yes one of the later face-lifts.
Old 7th January 2020, 08:13 PM
Digital speedo was only 2008 on but does work if you put that cluster in earlier cars it cannot be coded to exist or not exist. It can be set to Km or miles in MMI>Measurement Units which is useful abroad but also changes odometer to whatever units you choose.
Old 7th January 2020, 09:19 PM
I confess, this was my belief too, but been a while so wasn't going to make the claim.
Both my RS6s were 2009, with ACC and digital speedo for sure, and I've had digital speedo on all my > 2008 cars from memory, but no late model D3 with ACC that I recall.....
Old 27th January 2020, 04:04 PM
dangerdred dangerdred is offline
Yes, not sure how I missed it before now that it seems so obvious, but first two screens display Tripmeter 1 and 2.
Phantom Black 2008 A8 3.0 TDI SE ASB
