My A8 autobox has started grumbling a little whilst in drive. It doesnt do it in neutral or in park. The box performs well so really it's more of a minor annoyance. Any ideas what it could be?
It's probably lack of oil and filter changes. I would drive it till the end and rebuild.
'tis only a 2.8 fwd though. And I have an invoice for oil change back in 2015. I might have it done again..
Whats the millage on it?
2002 D2 S8 - Avus Silver, Valcona red leather, Dark Myrtle wood inserts, Heated rear seats, Heated windscreen, Auto dim rear view mirror, Bose, Xenon Plus, Servotronic, Extended leather, Heat & UV Reflective glass & Ski hatch. Gearbox went bang but she's sleeping safely away. |
103k is very very soon for it to fail my 2.8 has 143k and its on its original gearbox, clutch and never had its oil chanaged afaik until i owned it.
I believe Audi were replacing them under warranty as early as 40k
I thought that the 2.8s were ok re their auto boxes?!?!
She changes ok still, doesnt seem to be any other symptoms... |
Sadly they have all the same weak spots as all the others.
Does it grumble while moving, or while stationary as well? If moving it could be diff oil level. They are notorious for leaking out of the output flange seals, FWD versions even more so than quattro. The diff could be grumpy if it's low on oil. If it grumbles while in drive but stationary then that could be the torque converter. Hard to tell without hearing it, and even then not easy to diagnose without taking it apart. |
