Gearbox help
F125 switch fault is the first thing that springs to mind.
Does the car start and drive? Can you get the key out?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
Gearbox help
Key works as normal goes in turns on and cranks if I leave key and try to take it out in any other position other than park it won't come out as normal.. I get my parking sensors when in reverse working as normal as the back end is up against the garage wall I can turn it over in park do you know difference between oval black plug on f125 switch and the round plug as in the extra pins and what they are for doing my gearbox swap the have diff pugs I've used the plug from gearbox that happened to go bad as for the gearbox I put in it has oval plug but because of engine wiring loom had to use round plug.. I've got the loom from other car that the reconditioned gearbox came from at cost of 2600 quid so rebuild but what would I be missing as connector has 10 pin as apposed to 8 on round plug
Gearbox help
Gearbox help
http://forum.a8parts.co.uk/album.php...pictureid=1378 what is the difference
The differences between the two versions of the switch are almost certainly the cause.
We'd need to know more about the age and details of your car and the car where the gearbox came from to comment further. Also did you keep the F125 switch from your car and just move it to the new gearbox or graft on the other plug? From your brief description above it's not at all clear what you did re the F125 switch and connections when swapping the gearbox, maybe describe it step by step so it's obvious. How to rectify it, if you can, needs someone with an intimate knowledge of the interior and workings of the F125 switch..... Now who might that be?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (A much rarer model than a D2 S8 by the way!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 15th August 2020 at 08:28 AM. |
Gearbox help
I've not done any splicing W8AND has round plug Y729 XGA had round plug I put the round plug on Y729XGA gearbox so it would plug into W8AND wiring loom so basically just swapped the f125 switch over
OK so not 100% clear (too many "rounds") as I don't know which car is which, but I think from that your car with the problem had the later gearbox/F125 with the 10-pin connector and the gearbox you installed came from an older car with an 8-pin F125.
So you still have a 10-pin F125 but mounted on a gearbox that initially had the 8-pin version? Or is it the other way round?
Gearbox help
😂😅LOL sorry for the confusion I'm just so glad someone trying to help got carried away OK fresh start before any thing was done bother cars were both running. Y729XGA had reconditioned gearbox and oval plug on loom and f125 switch. Second car W8AND had round plug on loom and f125 switch W8AND had gearbox failure so I took it out and put Y729XGA gearbox in but I took of f125 and just swapped it over from W8AND now I have Y729XGA gearbox in W8AND car with round f125 switch instead of the oval f125 switch so as I could plug into W8AND loom... I sent pic of build sticker for both cars did you make sense of them.. Your helping a real novice here and it is well appreciated thanks🙏😁
