D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
Today I was mostly fitting some after-market HIDs that I bought because I gave bum advice. (Don't feel guilty Darren!
![]() To make this easy just remove the bumper and trims below the headlights. 2 bolts in the lower outer grills here: ![]() This is the kit I am using and the pair of LED sidelights next to them I got here. I already have a pair of these on the S8 along with after market HID dipped beams. ![]() Remember to ease out the inner wing liners or the bumper will not come away. Once it's off you have unfettered acces and a great mounting point for the ballasts. ![]() As you can see I have cable tied mine in place with 4 butch ties. The kit comes with mounting brackets but as I used this method on the S8 and have had no issues, I have done it again. When I get the HIDs for the dipped beam I will mount alongside or maybe piggyback. The rear cover of the cluster neads a hole cut in the bottom for the wiring. ![]() Once done you can see the difference with the side lights ![]() The fogs: ![]() A couple of tips. A. The ballasts need a lot of voltage and only one would fire if the engine was not running. Took me a while to realise this. The fogs would splutter and then only one would light on the battery alone. B. Fitting the bulbs was fiddly and in the end I removed both clusters. The first came off to repair and had gone back on before I started the HID. The bulbs have a plastic moulding and are thicker than the metal ones that they replaced, so a little bit of judicial bending was required to get the locking spring back in.
but remember folks...aftermarket HID is for show use only. I'm fed up of being blinded by dodgy HID's bolted onto a large selection of chav'd up wonders around my area. To be legal HID's need headlamp washers and auto levelling, of course, no one on here would ever consider running HID's pointing at pluto.
They are needed in the PF D2 though.. those lights sucked.
Another method of fitting the ballasts is to take the headlights out and you can reach down to the same brace Mike used above and cable tie them on (that's how I did it).
mike can you have front fogs on with dipped beam on the pf ? sometimes i drive with dipped beam and hid fogs as it give very good light on dark roads without blinding oncoming traffic
Audi S8 Phantom Black |
Yes you can Darren, my PF fog lamps are able to be turned on at the same time as the headlamp dip or main.
HTH I'd agree that the standard lighting needs upgrading, previously on other vehicles, I've fitted the likes of H4 130/90w's, which have considerably improved visibility, especially on the 'bike, but am in a bit of a quandry with my S8, as they're wierdo modern fittings and I so far haven't found any suitable replacements at sensible money....... any suggestions? Also..... Mike, I like the sidelights you have fitted, are they the 15 led ones? regards, Richard.
I Love the smell of petrol in the morning! Other vehicles 1968 Rover P5B Coupe (Modified & V-Quick, but I have to sell this now ![]() '92 Mitsubishi Pajero V6 (Petrol) Super Exceed (Gone now) '06 Harley Davidson Night Train Oh Yes....... The '98 PF S8! Last edited by Night Train; 16th November 2010 at 06:36 PM. |
Yes they are; and they don't cause bulb faults on the DIS.
Brilliant - literally
Thanks again Mike...
I Love the smell of petrol in the morning! Other vehicles 1968 Rover P5B Coupe (Modified & V-Quick, but I have to sell this now ![]() '92 Mitsubishi Pajero V6 (Petrol) Super Exceed (Gone now) '06 Harley Davidson Night Train Oh Yes....... The '98 PF S8! |
A well set up aftermarket HID does more good than harm. I can see far better at night with them. Washers only work when used and you have to stop and get out of the car to see if thay have been effective. Self leveling only works when you are 'not level' for more than a few seconds. So the bump/pothole will momentarily blind the oncoming driver no matter how good the self leveling system. Of course if you fill the back of your car with lead from the church roof and put the three well built thugs who helped you remove it in the back you should (morally) adjust your headlights before making your getaway! ![]()
which is the best kind of correct
Hi Mike, I fitted a pair of the LED sidelights, they really do make a difference to the front end aesthetics, they stand out more than my dip, fog or main beams which now look decidedly yellow when lit up......
Damn it, I'm just going to have to convert the dip beams to HID, I've seen a 55w (rather than the 35w) 6000k kit with 'digital' ballasts from HID's4You... any comments? Thanks...
Tags |
fit |
