Old 7th March 2021, 11:24 AM
Default Scan interpretation
I scanned a friends A4 diesel today as she’s got problems with the central locking. The key fob only opens the driver’s door.
Apart from some obvious faults that she didn’t know about (glow plugs and filler cap lock), 2 doors (passenger and rear right) show ‘02115 locking unit for central locking 008 implausible signal’. The fuel tank cap lock is ‘open or short to ground’.
Any ideas folks?
Old 7th March 2021, 11:54 AM
Jim, the following video might be worth watching. There's no commentary but it seems the error code can be resolved by stripping down the door latch mechanism and giving it a good dose of contact cleaner:
https://www.youtube.com/watch?v=HlYGjZbVkDg
EDIT: For the fuel cap error, is it a case that the fuel cap isn't locking? If so, then it might be another case of some lubrication being needed to resolve the situation. The following video shows how to remove it from a B8 A4, but the principle should be the same. Rather than remove it completely from the car in the video, on the back of the actuator is a small hole. Spray a liberal dose of contact cleaner in that and try locking/unlocking the car several times.
https://www.youtube.com/watch?v=KnW0Qpc09To
Old 7th March 2021, 02:34 PM
Worth checking module locations and making sure it’s not soggy - might not be the mechanisms themselves at fault
The fuel flap solenoids fail for a passtime - did the S5 last year and it’s a real pain in the behind (you have to replace the plastic insert under the flap as getting it out breaks it! Luckily it’s cheap.....
Old 7th March 2021, 04:10 PM
Thanks guys. BTW, Sean, there is a commentary on the video link, but the repair looks daunting! New actuator mechanisms are under £20 on ebay, so I think I’ll check the part number, get a new one and then try the repair for the other doors.
