Old 2nd May 2021, 05:44 PM
goldsax goldsax is offline
Default manifold actuator arms and bellows 2002 S8
I have looked through previous posts for the replacement of the actuator arm and bellows.
mine is a 2002 S8.
is there any up to date info for arms that work? as the last posts date back a couple of years.
also bellows, is there a part no., and where could I source them from.
many thanks
Audi S8 2002
Old 2nd May 2021, 09:11 PM
Markiii Markiii is offline
Replaced mine with the Ali ones from gruvenparts
Old 7th May 2021, 12:28 PM
27litres's Avatar
27litres 27litres is offline
There also used to be metal rose jointed ones on eBay from Poland or somewhere.
A bit difficult to install due to the metal licking pin, but work well.
I don't know a part number, but I believe the bellows are identical to P38 or similar vintage Range Rover cruise control ones.
Marty
____________________
2002 Audi S8 - Project
Family:
2009 Volvo XC90 V8 R Design
Sold:
1997 Audi A4
Old 7th May 2021, 03:57 PM
I thought that the idea of the plastic ones was that they would break if the bellows mechanism started to stick, But if you fit metal ones, you risk damaging the bellows mechanism.
But I’ve been wrong before!
I’ve got a little stash of the plastic ones that I bought some years ago, on ebay I think, with a minimum order of 2 or 3 pairs.
Old 8th May 2021, 12:45 PM
These ebay links may help but I am unsure of compatibility so please do your research.
https://www.ebay.co.uk/itm/VW-AUDI-A....m46890.l49286
https://www.ebay.co.uk/itm/Intake-Ma....m46890.l49286
Audi S8 D2 2002 88k mls
Old 25th June 2021, 10:31 AM
a belated thanks for the links.
i eventually bought the metal links you had highlighted which arrived from Poland.
fitted and problem solved.
the bellows works perfectly.
Audi S8 2002
