Old 8th March 2020, 09:19 AM
Default Headlight range plastic rod
Hi all
Do we have a solution for this NLA part? 4D0505465G?
Thanks Frank
Audi S8 D2 2002 88k mls
Old 8th March 2020, 10:36 AM
Two solutions. I prefer to make a new linkage from M6 race car ball joints and some M6 stainless threaded rod. I cut the original ball joint off the metal bracket which goes round the control arm (assuming its salvageable) and bolt the race car joint to it.
The more stock option is to buy an aftermarket sensor for the C5 A6 which usually comes with a new arm. Press out the bushings and ball joints from both arms and press the new ones back in to the original D2 plastic arm.
Old 9th March 2020, 12:16 PM
Stromaluski's Avatar
I never considered that... That's brilliant!
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 9th March 2020, 01:15 PM
It's normal for MJ. Her 'normal' is our 'brilliant'!
Old 24th May 2021, 02:23 PM
I am planning to do the same thing for mine, as you can see by the picture it is currently sitting together but is in two halves. Looks to have been melted? Is the curve critical or can I be a few degrees / mm's out?
Or are you making a few for general sale??
Paul
Gosport UK
________________________
Polestar 2 Long Range
Honda Jazz
Harley Low Rider 107 Stage 2
Harley Sportster 1200
Old 24th May 2021, 02:32 PM
How odd. Never seen one melted like that - has someone tried to weld it back together?
If you make a set and get the length slightly wrong then the headlights will need to be recalibrated which is simple enough with VCDS.
I can make the balljoint sets on exchange if needed.
Old 24th May 2021, 03:12 PM
I can only guess that is the case. Never been an issue with headlight alignment until it snapped.
Paul
Gosport UK
Honda Jazz
