Old 10th November 2021, 07:50 PM
For the crack the best would probably low viscosity UV resin like used in windscreen chip repair. They come in different viscosities. Depends how long the crack has been there, if a long time then there is likely some dirt in 5here so not sure how well it would seal up.
Old 5th December 2021, 08:38 PM
jonnypym123 jonnypym123 is offline
Mark I had the exact same issue the other week right rear outer cluster indicator light was dimmed along with taillight, It was either rain or ice that caused it and was working the next day, worth trying to reseal if you can. DId the inner one last yearplastic glue and headlight silicone and some patience in getting it apart
