Old 21st September 2023, 09:21 AM
Markiii Markiii is offline
did you not still have to go to that effort to remove it? or did you go with the destroy it option?
Old 21st September 2023, 09:48 AM
Ronin Ronin is offline
I went with destroy and replace option, much quicker and better result, because you end up with a new sensor that's not a ticking time bomb unlike a 21+ year old one.
Vast majority of them fail where the cable goes from the strut to the cars body, there is nothing to break in the sensor itself, it's just a coil of wire encased in plastic.
Old 18th November 2023, 04:56 PM
well as expected the sodding sensor snapped when I tried to remove it.
If I drop the drive shaft can it be pushed through or do I need to tap it back out the way it went in?
Old 18th November 2023, 08:37 PM
I made a few holes with a drill in mine and picked it all out out with a screwdriver, 10 mins work.
Old 18th November 2023, 09:38 PM
Self tapper into it and pull on that...
Old 19th November 2023, 12:15 PM
Thanks chaps. It's out
Now how the hell do you depin the connector?
Old 19th November 2023, 06:54 PM
https://www.ebay.co.uk/itm/235226700...Bk9SR-L8rJL9Yg
Old 19th November 2023, 07:01 PM
I have the tools just can't get anything to release. Is the pink bit a locking mech that needs removing or are they supposed to unlock with it in place?
Old 20th November 2023, 08:30 AM
The purple tab inside slides out a few mm to release the pins, if it's stiff spray some wd40 in there first.
Old 20th November 2023, 09:22 AM
thanks will give that a try
