#31
So I've had the chance to give the car a quick drive now... basically as soon as you put your foot down the car revs with little drive, then changes up a gear at a time until finally hitting about 3rd gear... do it a few more times and it goes in to limp home mode - i.e. stuck in 4th. Driving it again in manual mode showed this slipping, accompanied by a fair bit of judder actually, in 1st, 2nd and 3rd gear but not at all in 4th or 5th gear.
Also, as soon as you reset the errors the gearbox starts working in all gears again immediately but with the slipping in the first three as before. Hence, it's not because of the 'oil overheating' that's causing the limp home. The limp home is being caused by the fact that the system is sensing there's far too much speed difference between input and output shafts and therefore there must be something wrong - the diagnostics don't seem to be able to tell anymore than that. I think at one point I read the fluid as being at 8 degrees fahranheit. Fluid that came out still smelt sweet with no burnt smell and I'm led to believe that a slipping wet clutch will burn itself off and the oil will smell burnt. I can also understand that with a wet clutch, the viscosity of the oil must be absolutely critical for them to work as they should. Also, I can't see how this could affect it but I'd mention it anyway, there is a (quite a bad) leak from the final drive, drive shaft oil seal. Just wondering if this was so failed that the one wheel was slipping loads and just confusing the hell out of the electronics... clutching at straws I think but you never know! Any further advice would be greatly appreciated. My thoughts at the moment would be to do a proper service on the gearbox, drop the sump pan, change the filter and fill it with proper genuine Audi oil. If that doesn't cure it then we 'scrap' it or fit a recon box. Alternatively, has anyone ever been able to rebuild one of these things themselves or are there lots of special presses etc needed to tear it down? |
#32
Anyone know if the genuine oil is still the yellowish green colour? |
#33
Whoever quoted you £1,000 labour to change the gearbox probably doesn't have a clue. I paid £250 and it was in and out in four hours. That was with Ben who can do it quickly being familiar with these cars. The most you should pay is £600, I wouldn't pay more then £350 for a reconditioned gearbox either unless it was freshley rebuilt. No one here has rebuilt one but Tozo on quattroworld is a ZF gearbox god, he has refurbished loads and even converted 2 D2 S8 models into 6 speed twin turbo manuals, we need him in the UK!
If your seriously considering getting rid, I could be interested as a project car. Also, I have heard very good things by friends about OSC Motorsport in Rugby, may want to speak to them.
2009 Audi RS 6 Saloon V10 - 420mm Ceramics, Keyless, Soft Close, Adaptive Cruise, Glass Sunroof, Blinds, Twin Pane & UV, Freeview & DAB, High Beam Assist, MTM bits, Audi Exclusive Bits, MRC, Milltek, GYEF1 ASY2's, Bluetooth streaming music to AMI mod - 753 PS/1021 NM 2016 Audi S3 Saloon, Sepang, S-Tronic - B&O, Tech Pack etc... Company Car 1995 Audi A8 4.2 V8 quattro Sport - Bose, Solar, Blinds |
#34
Transmission. Do you get any noise when the car starts, this could be cavitation, where the filter is blocked and the ATF can not be sucked up quick enough by the pump which is running at engine speed. I cured this with a filter and ATF change. 8 deg F is way wrong. it needs to be at 30 deg C for level setting during the fill, and will climb from there. Next possibility is that the valve bodies are malfunctioning. Have a read of this post for more information. The transmission sticky also has loads of information. There was also a post on Tyresmoke in the A/S8 section by someone who did a valve body service, but I can't find it at the moment. He found that several of the solenoids had mesh filter screens and they quite fouled up with gunge. Slipping clutches are the most common failure. Rebuilding is more fiddley than difficult. All the parts are available from ZF and I for one would like to have a go when I have time. There is a guy in North Yorks that service the HP25 for free!!!! But he does Land and Rangerover versions. There are however a couple of special tools needed. Quote:
A full ATF and filter change (don't forget the 'O' seal) will cost about £120 tops in parts alone. The ATF is available in bulk of 20Ltrs to save money. Sell the left over on to someone on here.
Conan (the Librarian) Watch it if you dare Currently, 2000 S8, Merlin Purple, Leather Pack 1, Winter Pack 1, SPAX adjustable suspension, AP Racing 6 pot front caliper, 385mm fully floating disks, EBC Yellow Stuff Pads, Black Diamond grooved rear disks and predetor pads, D2 Doctors Brake Block. 1997 4.2 A8SQ - the Projekt. 12 years and ongoing! 1997 4.2 A8SQ - Ming Blue. Restoration sat waiting; saved from the Scrapyard 2003 C5 Allroad 4.2Q - Cobolt Blue. Towing car. Laid up awaiting manual conversion. 2005 C5 Allroad 2.5TDi FE - Grey - Workhorse. 2015 Q3QS SLine - Daytona Grey. Lots of extras! Long Haired Admirals cutter. Previously 2003 C5 A6 1.9TDI FWD - Loaner from D2 Doctor Lifex 1997 S8 - Ming Blue. Loaned out and written off. I loved that car. My first engine swap after cambelt failure. 1996 4.2 A8SQ - Ming Blue. 178k on a cambelt! Trader's 8. Delivered to A8Parts at Lifex. 2003 2.8 A8SQ - powder blueish. Fill in for a while. Sold on. 1998 1.8T A4 Avant FWD. Ming Blue (there's a theme here), PEX for the 97 S8. And a list of non VAG going back 40 years before I saw the light. |
#35
Should have said 84 degrees, not 8, sorry!
#36
84 deg, Phew! No way to test valve body in the car apart from the output tests on VCDS. You may need a genuine lead to do this though. It activates the shift solenoids etc and if they throw a fault records it in the fault table I think. If I were in doubt about the fluid, and you know the filter wasn't changed then I would change both as a DIY option before commiting to more expensive lines of action.
#38
when my transmission oil was changed, with filter, 7 litres of fluid went back in which given the capacity is about 9 litres is pretty much all you can expect to get out without draining the torque converter.
If the fluid appears wrong type you might want to flush with fresh fluid and change again - but that's not a cheap option! I'm aiming to have my fluid changed again in 2 years (will be about 10k miles) which should get some more of the old stuff out. |
#39
Proper oil change takes 11-12l. After initial fill-up before starting car they connect pump/meter between oil radiator and gearbox in return pipe and this device collects dirty oil running from gearbox through the radiator and then pumps the same quantity of fresh oil until returning oil is seen clear either in clear hose or window. After that they reconnect the pipes , warm up gearbox and check final fluid level. |
#40
Popped in to Revo Technik yesterday and told them what happened. They immediately asked 'what type of oil did they put in and is it full?' We showed them a sample of the oil we'd taken out, which is red and quite thin and again they immediately said it was totally the wrong oil, wrong colour and far too thin and watery. Explained that we might be able to save the box my doing a couple of full flushes and filter changes.
So next step is to contact the original garage who assured us they did it all properly and 'absolutely' used genuine Audi 'box oil - even listed the Audi part number on the invoice. Clearly they haven't so we will be asking for a refund, inconvenience compensation and that we will send a bill to them for a rebuilt box if we can't get this one going. Very frustrating when the guy supposedly worked for Audi for 20 years before setting up on his own (and this is the not the best sorts of things to be doing for your reputation when you're just starting out!) and assuring us he would do it right - we knew how sensitive these boxes were before doing it! Depending on what they say and how they react, we may ask them to put it right or we just do it ourselves properly so we know it's been done to our standards! Will update in a few days hopefully.... |
