Old 17th January 2012, 08:58 AM
On the Elsa instructions for strut removal, it says to unscrew the air connection, AND NOT UNSCREW THE VALVE. Does this suggest the valve can be unscrewed?
Good luck
Old 17th January 2012, 09:18 AM
Stuarta Stuarta is offline
Already tried XP mode (having spent an hour doing work-arounds to get it to work on my home edition of windows 7 - yes it DID work - but then asked for a serial number!) but not the others - maybe when I get time.
Gave up on XP years (and years....) ago.
Have tried epoxying the leak this afternoon, will wait until tomorrow before testing to give it plenty of time to cure.
Here's hoping!
p.s. - while I was driving around looking for the epoxy, the warnings cleared and reappeared intermittently - sometimes gone for 10 mins at a time. Wierd.
Old 17th January 2012, 02:23 PM
OK - partial result. I believe I have at least reduced the leak as the system now activates and the front of the car will rise. Still leaking though as a) I can hear it and b) the compressor shuts down through overheating after a bit. Will need to wait until tomorrow to try again to see if it's the same leak or another one. Shouldn't have gloated to the wife.......
Old 17th January 2012, 02:50 PM
Lol.. Typical.. Though maybe another application of sealant would do the job.
Old 18th January 2012, 02:03 PM
Ok - bit the bullet and bought a new damper today. On closer examination, the remaining leak appeared to be INSIDE the old one so not much to do there.
One question - the connector for the inlet valve, at first glance, appears to be unthreaded - I didn't expect this. Obviously, I'll find out tomorrow when I remove the old one but before that - any comments?
Also, the system again seemed to clear the faults albeit temporarily , when driving, usually around the 60-65mph mark. Bizarre.
Old 18th January 2012, 02:19 PM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
I was going to say-don't burn that compressor out...mine died and cost me nearly a grand from audi-just for the part, I fitted it myself... (after every after market one that "guaranteed" to fit-didn't!) and I get a decent discount from Audi
Get the new damper on asap lol
Bex
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Old 18th January 2012, 04:11 PM
Looking at it on ELSAWin, it says to unscrew the pipe going in, being careful not to remove the bit it goes into.
Not a simple process I'll try and get the procedure uploaded.
Old 18th January 2012, 04:18 PM
Here you go..
Uses that all-important tool kown as 'bit of wood' too
Old 18th January 2012, 05:13 PM
WOW! Thanks PsYcHe - spent the last 3 hrs messing with virtualbox and XP trying to get my damned Bentley manual working - now I can look at what I NEED to do instead. Cheers!
p.s. Nice to know the Germans can have their non-technical terms occasionally!
Old 18th January 2012, 05:56 PM
The ELSAWin I'm using came with an XP install in a VMWare machine (so you'd just need player which is free), the only thing is that it's in Russian so can be a fiddle sometimes.
