Old 21st April 2012, 04:22 PM
A8_Tony's Avatar
A8_Tony A8_Tony is offline
Unhappy B&O - No Sound
Not sure if anyone can help with this, but my system is producing no sound.
Tweeters didn't pop up like they normally do, and the AMI is showing as "Interface Paused".
No audio from radio, nor nav either....
...HELP!!!!
A8OC Founder
The A8 Owners Club here
Old 21st April 2012, 04:23 PM
Interface paused is usually when you mute the volume.
Have you got VCDS to check it? Could maybe even be that the connection to the AMI is loose.
Old 21st April 2012, 04:28 PM
A8_Tony's Avatar
I've got a version but not a genuine one....must get one, I'll check the connections and see if I can find anything there
A8OC Founder
Old 21st April 2012, 07:30 PM
47p2's Avatar
47p2 47p2 is offline
Switch the vehicle off and wait 20 minutes, then disconnect the negative lead, then disconnect the positive lead, then using a jump lead (piece of wire that has two crocodile clips) join the positive and negative leads together and leave them for 15 minutes. After 15 minutes remove the jump lead (crocodile clips) and reconnect the positive lead to the battery terminal and tighten up, then reconnect the negative lead to the battery and tighten up. Start up the engine.
Jump lead with crocodile clips.....
Must not be connected to any terminals that are still connected to a battery
Nite Blue 3.0L SE Quattro
Old 22nd April 2012, 09:34 AM
A8_Tony's Avatar
What does this achieve? Does it reset something? Discharge the battery? Forgive my apparent stupidity, but I'd rather ask than not know
A8OC Founder
Old 22nd April 2012, 09:53 AM
It will basically do a full hard power reset of the system, so will allow any capacitors, etc. to drain properly.
Old 22nd April 2012, 09:47 PM
It will erase volatile memory
Old 22nd April 2012, 10:03 PM
Tony, You've probably done this, but just in case
Are you aware that holding the volume know (to left of shifter) for a few seconds, switches the system off.
To switch on, just jab it down again.
