I've started on the job of replacing the boot lock and moving the camera to the nearside. So, boot lock back in place and mostly working. It unlocks with the key fob and locks and unlocks with the key. BUT - it doesn't lock/unlock with the central locking with the rest of the car. I can see what's supposed to happen (I think): there's a short rod that goes from the key barrel to a pump (?) of some sort and, although this moves manually if pulled by hand (and disengages the key barrel), it does nothing when the rest of the car is locked/unlocked.
Now, the rod has been cable-tied up whilst it wasn't being used. Could that have caused something to fail? Oh, and BTW - no smutty innuendos about short rods being pulled by hand please. ![]()
. Nite Blue 3.0L SE Quattro |
Don't tell me no-one has the answer to this one?
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .Planned mods: auto-dimming rear view mirror, dash cam (as steamship's), fit the ski hatch, refit philips drl's (or maybe not - nope, definitely not - horrible botch!). Last edited by The_Laird; 24th September 2012 at 11:59 AM. |
Does the central locking pump run on for an extended period of time when you lock or unlock the car?
The pump (?) thingy that you reference is the vacuum operated bit of the locking for the boot which is seperate from the electric boot release via the button on the drivers sill or the central button on the key. The vacuum (or pressure) created by the central locking pump pulls or pushes to lock or unlock the boot so if it isnt moving when the locking or unlocking is activated then I can only assume that the air is being lost somewhere. This would however result in the pump running on longer than the usual 1-2 seconds. For the purpose of testing the locking on a D2 can be opened or closed using your mouth and sucking or blowing (this is going downhill rapidly isnt it!) and as such should move the bellows on the boot lid in or out....
At Work to Break: 2001 TT 8N 1.8T Quattro with a loud exhaust! 2000 A8 D2 3.7Q Non Sport Ming Blue 1999 A8 D2 4.2Q Non Sport Santorin Blue 2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather 2001 A2 1.4 TDi 2006 A6 C6 2.4 Quattro Avant Canyon Red At Work to Drive: 1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch 1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash 2008 Fiesta Sportvan x2 2002 Transit 2.4 LWB 2007 VW Crafter Recovery Truck 2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart 2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses. At Work to Hire: 4x 6 Berth Sunlight Motorhomes |
I don't know the answer, just trying to apply some logic to the problem.
AFAIK the boot central lock is operated by a vacuum system, like the rest of the central locking. On my (admittedly earlier) S8 you can hear the pump working (about a second) when you lock/unlock the whole car. You then still have to press the boot button in to open it (assuming you've set the boot lock position to allow that). The key is clearly just a local mechanical operation, so most of the mechanism must be OK as that works. On my car just opening the boot with the remote boot button makes a sort of "solenoid" noise, no air/vacuum involved, so I guess that's a local unit in the boot lid. So it sounds like you "may" not have the vacuum deadlock unit connected properly for the boot. Or you may just have the keylock in the wrong position..... ![]()
The central locking pump only seems to run for a couple of seconds and the rest of the system works fine. The short rod that is connected to the lock and then to the 'pump' thingy doesn't move at all, even when disconnected. Is it easy to remove and check?
I wonder if it was disconnected when James replaced the lock with the camera? It seems pretty inaccessible though
The rod without the 'hook' is the item in question
Jim you are welcome to have a look at mine to see how it works if you like?
cheers
Audi S8 2002, Black (even the chrome bits) Maserati Granturismo 2008, Metallic Nero Carbonio Audi S8 2015, Daytona Grey |
The photos are from David's car - already had his in bits! I think I just need a guide as to how the short rod mechanism is connected to the central locking pump. I'll try a PM to James to see if he can shed any light on it
