Old 20th October 2012, 05:11 PM
MAM MAM is offline
Thats the one I found to get the code for the antenae. What caught me out was that I expected the original connections to have an antenae. I was expecting the yellow plug to come off the old module and straight on to the new module.
Do you know what the original yellow plug is for?
Deep Green 2006 '56' A8 4.2 SE, B&O & Exclusive Interior
Extended Aluminium, Oak Sepia Wooden Trim, Extended Leather
Green Exclusive Dual Colour, Heated Comfort Leather Interior
Green Alcantara Headlining, Pillars, Rear Shelf, Door Inserts
Green Trimmed Mats, Seatbelts, Steering Wheel, Centre Armrests
DAB, Freeview, ACC, 4-Zone Climate, Soft Close, Electric Blinds
Old 20th October 2012, 06:32 PM
Somerandomguy's Avatar
Not off hand, ill have a look to see if etka has details. I think the purple one connect to the antenna amplifier, which then goes to the roof antenna
2004 A8 3.0 TDI Sport Brilliant Black
Came with: Black Valcona/Alcantara Leather, KESSY, rear blind, flappy paddle gear change, Phone Prep, TV
Added:Bluetooth, AMI, Hybrid TV, Parking plus, Ski hatch, towbar, DAB, Umbrella Holder, Reversing camera, Auto lights, Wheel refurb
Things to fix: Turbo fault, power drain
Old 20th October 2012, 08:32 PM
Pretty sure the original had 2 antennae connections where the new one has none (unless you have an rSAP module)
Old 22nd October 2012, 07:45 AM
MAM MAM is offline
As I have had to drive the car with the install only 90% complete, why does the MMI not run? The optics are in the module, but the loom is not plugged in. Surely this cannot confuse the system that much.
Old 22nd October 2012, 07:52 AM
im guessing by having no power you have a break in the most ring, so sounds probable to me, one of the experts will no doubt be along shortly to confirm
Old 22nd October 2012, 09:39 AM
Exactly that.. If any module in the loop fails (or has no power), the whole loop is down.
Old 22nd October 2012, 09:41 AM
MOST annoying . . . . ahem. . . .I'll get my coat
Old 22nd October 2012, 11:41 AM
Very... if something daft like tv tuner fails, then it's all dead
Old 26th October 2012, 05:27 PM
MAM MAM is offline
I have installed the bluetooth module, new connector and dongle. The MMI recognises that I have bluetooth and allows me to delete pairings and change the code. What I cannot do is pair my iPhone 3GS with it - The iPhone does not find the car.
Could this be due to the MMI software version? I am on a lowly 2120.
Old 26th October 2012, 07:10 PM
Probably, you can get a backup from the dealer, ebay or google "E73A79E9B4FE02DFEAF53176A13AD9C93B5B20D2"
