Old 21st January 2009, 10:35 PM
Default The Audi Build Sticker. A Wealth of information
Many items of equipment are fitted at the factory depending on when the car was built, and from an external appearance and drivability they can seem identical. At this point, the only real way to tell is to refer to the build sticker.
The sticker is on the inside cover of your original Audi Service booklet, and a dupliacate is stuck inside the spare wheel well. This square, white sticker has every code on that is required to work out exactly what part is needed for your '8. An example is below:
Old 22nd January 2009, 09:31 AM
zytec
Guest
Posts: n/a
I'm sure many know this but for those that don't it's worth putting here:-
To find out what all the options on your code sticker are go here:-
http://igorweb.org/equidec/Default.aspx
(using the codes from above posting image as an example) enter them like so
X2B;BOA;C8C;GOQ; ....etc etc
hit decode when all are entered and you get this list:-
X2B = National sales program Great Britain
B0A = Component parts set without country-specific design requirement
C8C = Alloy wheels 7.5J x 18
G0Q = 5-speed automatic transmission for four-wheel drive vehicle
H6V = Tires 245/45 R 18 96Y
J1G = Battery 450 A (92 Ah)
M72 = 8-cyl. gasoline engine 4.2 L/220 kW V8 Motronic, closed-loop catalyt. converterbase engine is T7W
Q1D = Sports front seats
1BE = Sports suspension/shock absorption
1AH = Electronic differential lock (EDL)
1G3 = Alloy spare wheel with original equipment tires
2PV = Leather trimmed sports steering wheel
1N1 = Power steering
5RV = Right exterior mirror: aspherical
5SJ = Left exterior mirror: convex
T7W = 8-cylinder gasoline engine 4.2 L Unit 077.5 (aluminum)
0JZ = Without determination of weight categoryfor front axle
4UE = Air bag for driver and front seat passenger
0YZ = Without determination of weight categoryfor rear axle
0G7 = Tiptronic
8AE = Radio "RCD310 MP3"
8GL = Alternator 120 A
8FA = Without second battery
8RV = 10 speakers (passive)
1KE = Disc brakes, rear
1LC = Disc brakes, front
3FR = Electric sliding/pop-up solar sunroof with automatic pre-selection
Old 22nd January 2009, 10:47 AM
0G7 = Tiptronic
Yep, we use it so often, I forgot to mention it
Thanks for the post
Old 30th April 2011, 06:42 PM
I would like to add that on bottom line next to weight is official fuel consumption figures in l/100km and gCO2/km town/highway/combined/CO2
Old 26th May 2011, 01:33 PM
Curtis's Avatar
Curtis Curtis is offline
great i have a abz 4.2 and my petrol card company worked out a average of 18l/100km and i though they where mad.looks like they where right it sucks juice in town
Old 26th May 2011, 01:35 PM
Curtis's Avatar
how would i tell if i have pf blue or pf black leather interior?
Old 26th May 2011, 09:40 PM
[quote=Curtis;22297]how would i tell if i have pf blue or pf black leather interior?[/QUOTE
I guess you've tried looking , so get out your service book, have a look in the front for the page with a sticker, like the one at the top of this post. If you don't have the service book, have a look in the hole where your spare wheel is kept. Hopefully your duplicate build sticker is still there.
When you have the sticker, check the codes for leather (they may be different to the codes on the exaple at the top of this thread), get the code decoder,also mentioned in this thread, and type in the codes from your sticker. It should then tell you all about your car, including the type and colour of the leather fitted.
If you post a picture of your build sticker, I'll decode it for you if you want
Old 25th July 2011, 10:13 PM
Curtis's Avatar
well i managed to find out the interior colour.its bt -anthracite, so which will be the best colour to match if i want to replace door panels and seats black or blue? Or is there a anthracite its just hard to come by?
Old 9th November 2012, 07:26 PM
Richierich37 Richierich37 is offline
Superb wee decoder, cheers
Old 13th May 2016, 04:09 PM
oldnick oldnick is offline
being a wet and miserable day here in southern france I though I would have a look to see what the options codes list in the service book meant , intended to do it for a few years
clicked on the igorweb link which didn't work , but got there thanks to mr google
apart from discovering that I had acoustic glass [ whatever that is ] I discovered things that I don't have , and wouldn't know what it was if I did !!
eg
4LA without controls ...I know they are introducing driverless cars but I didn't realise I had one
3HA without leather parts control ...the mind boggles
1SA without additional front underbody guard ...would that mean double thickness ?
in addition I have CBC but audi must be keeping it secret as it is not in the list , or maybe they are just telling about something else I don't have !
ah well , kept me out of mischief I suppose
