Old 30th August 2013, 08:52 AM
A8 Owner A8 Owner is offline
Default diagonal brakes binding
This is strange one.
Car has been at garage having a track rod end, and the air bag light fix done.
Past MOT other than them. So all work done . They went to road test it today before they ring me to pick it up. The diagonal wheels are binding. Anyone had this? as there thinking its ABS pump.
Thats alot of money been told. so any help be greatfull
Old 30th August 2013, 09:12 AM
Not just the calipers sticking?
Old 30th August 2013, 09:43 AM
Think there going to look into that. They just think its odd both played up on same day tho.
Old 30th August 2013, 10:42 AM
they have checked calipers and they dont think its that. As he said he would free them off and say if it happens again i would need new one's. He thinks it is a electric problem. Is there anyway by doing the pass air bag light fix, that could cause a problem.
Old 30th August 2013, 11:40 AM
Could be the handbrake that's the problem,especially if they've yanked it hard doing the MOT. Might not be returning properly to free off the calipers.
Old 30th August 2013, 01:00 PM
I think that thats a good call - it provides the connection between the brakes "suddenly" binding and the car being in the hands of the testers.
Old 30th August 2013, 03:06 PM
roboblob roboblob is offline
Did they remember to take the handbrake off before they moved off , I seem to remember one of out members doing that at a meet ,boy did the air whiff behind them
Old 30th August 2013, 07:16 PM
Old 30th August 2013, 08:34 PM
5pm update was................... They had it on the ramp, and were about to undo brake bleed nipple. To see, if they did this, will the brake come off or stop on.
If it stops on, there going for piston stuck on both sides.
If it frees them off, there looking at ABS pump, as there saying, that would mean that pump is pumping wrong fluid value to brakes.
Think thats right.
Does that sound right?
Old 30th August 2013, 10:17 PM
Not necessarily, are the D2 not a 4-way ABS system with an independent feed for all 4 wheels, so I'd find it strange that both rears have gone.
I'd pop the calipers off and rewind them to see what happens as I'm struggling to see what could have caused both to go at the same time just at MOT time.
A similar (though reverse) issue is found with the XC90 (like the missus has). As it's a foot operated handbrake with noddy little shoes inside the hub (a daft system, but anyway), if the tester can't generate a decent amount of pressure with their left foot, then it won't pass an MOT.
