Old 9th July 2014, 09:55 PM
Palmer Palmer is offline
Default spacers
For the 8 obviously need to be 5 x 112 but whats the center bore size?
Anyone recommend any??
Old 9th July 2014, 10:23 PM
Yes. Don't
Old 10th July 2014, 05:28 AM
Centre bore should be 57.1 and wheel bolts with curved shoulders if you're intending to use your existing bolts. Some wheels used angled shoulder bolts so you may need to change all of your bolts including locking wheel nuts if that is the case
Old 10th July 2014, 06:58 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
What size you after?
A friend has some for sale.
[center]
06 3.0TDI Quattro:
Options:
Old 10th July 2014, 12:33 PM
Ive got new wheels bolts already came with my new wheels lol
20mm?
Old 10th July 2014, 12:42 PM
ScottD3's Avatar
he's got 10mm and 8mm.
I'll keep my eyes open for you.
Make sure you get hubcentric spacers if you're going that big.
[center]
06 3.0TDI Quattro:
Options:
Old 14th July 2014, 06:28 AM
texas2201 texas2201 is offline
what is your friend asking for the 8mm spacers?
Old 14th July 2014, 09:10 AM
I could be wrong but I don't think 8mm will be hubcentric, they are probably to thin to make them hubcentric as hub normally protrudes from brake disc by 8-10mm to center wheel. And at 8mm they will be to thick for wheel to actually reach the hub.
If you use thin spacers like 3mm you can still centre wheel on the hub, if you want hubcentric you need to go for 10mm+.
Old 14th July 2014, 12:53 PM
ScottD3's Avatar
8mm can be hubcentric, I borrowed a set once and they was hubcentric with longer bolts.
I'd personally not use any spacers unless they hubcentric and something as small 3mm or 5mm don't really seem worth it.
Mate said £40 for the spacers.
[center]
06 3.0TDI Quattro:
Options:
